hydro and rear differential filters 7040
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: hydro and rear differential filters 7040
    Posted: 10 Aug 2020 at 8:23pm
any one have any suggestions on how to make the process of changing filters easier?  The new o rings suck trying to get them in and then the end plate or cover goes in or on very hard  should a person place the filter in the end cap first before placing in the rear tub?  or can i place the filter in the housing and then put the cover on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 8:55pm
Don't take old oring out unless bad. Start cap in at 45 degree until through first oring, then straight in.           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 9:10pm
thank you mack i tightened the bolts evenly and then tried to tap with a hammer to close the sealing gap as i tightened the bolts  i think im going to take back off and retry as i damaged the end cap and im not happy with my results
