A-C Bal Pak bearings
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: A-C Bal Pak bearings
    Posted: 29 Aug 2010 at 8:22am
I found some used bal pak bearings for my old disk and was wondering if it would be wise to attempt injecting some grease into them? I have a grease needle that could possibly be worked thru the seal. Has anyone ever found a cheaper replacement for these oddball bearings?
Thanks in advance.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 12:05pm
I do not see anyway of injecting grease into the ball bearing portion of the Bal-Pak. You could add to the grease cavity's on either side of the ball bearing. If you do try drill into center section thyen inject your grease, close-up hole with whatever you choose. I was unable to find any bearing that matches the Bal-pak dimensions.
This page was generated in 0.031 seconds.
