Large "Barn" Project ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Large "Barn" Project ??
    Posted: 08 Aug 2020 at 7:00pm
I have an acquaintance  that is wanting to build a 60x120 "pole barn" that will be used for "mostly" boat/rv storage, but is also going to be 100% climate controlled with 50% utilized as a "studio apartment". The side walls are 16',not sure on the exterior siding yet. He's leaning towards a true "pole barn" construction, but I suggested 2x8 stud walls on 2' centers on top of a monolithic poured floor Stern Smile . Am I wrong in my thinking?? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 7:15pm
16 ft 2 x 8 studs is going to get expensive !
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 7:28pm
More so than framing in between the posts later ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 7:35pm
pole barns are anchored TIGHT to the ground ( poles buried in concrete.. You can tie them together with  horizontals and finish the outside with tin... tin does not fit on vertical studs too good... depending on what he needs on the inside, he is going to  insulate and put additional framing.......
i would think 16 ft tall studs would be hard to anchor down against high winds.
Edited by steve(ill) - 08 Aug 2020 at 7:40pm
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 7:46pm
Lots of large pole buildings built here for shops, completely insulated and finished, seem to work good.  Can also add an office on the side if you need and it will be as nice as many houses.  My brother did this, 80 by 100 shop with a 32 ft square office on the side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 7:58pm
Expense wise look into red iron building projects.  Cheaper and more durable than Pole or conventional structure in the long run.  Can be sized to meet needs and clear span.  Steel Sided, no worries of Treatment chemicals destroying tins, or affecting occupants.  No conventional Trusses so height becomes Nominal at Joist Beam height.  Poured floor/rim Footer foundation, Cast in place bolting positions, that is why used in commercial style construction.  Faster build, straighter lines, stronger materials.  My Next structure will do this as can build Huge for the same cost as wood where less expensive insured.
Are many others
Edited by DMiller - 08 Aug 2020 at 8:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 5:54am
wow someone has very 'deep pockets' ! 7200 sqft with heat and A/C that's over 115K cuft of air to deal with....ka-ching, ka-ching..
Obviously a professionally designed/installed 'PEX in well insulated concrete floor' is the starting point... Up here sprayfoam is $4 a foot and the only 'sane' way to do a building that big to seal and insulate. I'd run all electrical outside of the walls,in conduit. Saves a ton of money in energy costs.
I'm thinking white tin ceiling and walls, with windows  all around ,say 14-16' up,to let in daylight...
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 7:49am
A 3600 sq ft “studio apartment”.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 5:25pm
Yes Jay, this cat has virtually "endless pockets". His family runs an asphalt company in Chicago Wink There will be NO exposed framing, conduit ,plumbing or heating elements exposed Smile. This will be finished "inside" like a 5 star hotel TongueTongue.
GeneD14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GeneD14 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 11:47am
In many areas a pole barn style building is taxed at a lower rate than conventional stud wall framing. But it sounds like money is not an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 12:04pm
Money not a problem, Red Iron.
This page was generated in 0.174 seconds.
