Door Ajar Switch On F250 ?? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Door Ajar Switch On F250 ??Posted: 04 Aug 2020 at 4:51pm |
Browsing the local O'Reilly's parts site for this switch, and there's a $20-25 variation in the switch depending if it's the "front door" or a "rear" door
. Yes, they are different part #'s, but what might be the difference between the front ant back doors ?? My truck only has 2 doors ![]() . Thanks
john(MI)
Posted: 04 Aug 2020 at 10:30pm |
Take the cover off the door and find the switch. If it closes when the door is closed, pull the wires off and twist them together and tape them up. If it's normally open then just pull the wires off and tape off the ends. Many problems in doors are usually caused by a bad ground. You may want to troubleshoot a little before you spend money on parts you don't need.
Michael V (NM)
Posted: 04 Aug 2020 at 10:33pm |
Lotsa WD-40 on the door catch, that's where the switch is, and it's prolly just sticking..
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 05 Aug 2020 at 5:44am |
I always thought a door was a door NOT a JAR !!! As to WHY the fancy computer doesn't display door OPEN, is anyone's guess.. ajar and open are both 4 letter words, though not the ones I'd like to say to the 'engineers' that figure a door is a jar ! ok, if the truck was 'oil sprayed' or 'undercoated' , the waxy stuff could have migrated to the switch and 'gummed' things up....spraying brake cleaner and opening /closing the door a few times may fix it... Jay
