GPS question
EDWD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EDWD45 Quote  Post ReplyReply Direct Link To This Post Topic: GPS question
    Posted: 04 Aug 2020 at 2:48pm
My story (short version)-
     I own a 40 acre forested parcel bordered on 3 sides by National Forest.  The sw corner and se corner are marked by pins the feds put in (along a section line).  I've had a general idea where the ne and nw corners are, but not really sure.
     Now, the Feds are informing me they intend to log the 40 north of me (among others).  I'd like to make sure they stay on their side of the line, but I need to know, after 55 years of ownership, exactly where the line is.
     My  first question is... Is there a relatively reasonably priced instrument that can give me accurate readings in longitude and latitude, in order to find my "not for sure" corners?
     My second question (pun intended) is... At 46 degrees N, how long (as in distance on the ground) is a "second"?
     Thanks in advance.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 3:19pm
Probably pretty soon one of the smarter ones on here will answer the "second" question but I think any GPS will give you the coordinates of where you are standing and which direcction to go to get to the coordinates you choose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 4:39pm
you or the State needs to have a VERIFIED SURVEY to prove the point.. Not your GPS.
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 4:59pm
I agree here!  If you do it, then it is your word, and their word.  Get it done correct, save yourself a BIG issue, and pay a few bucks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 5:12pm
Well ..'they' should have a real good, uptodate, accurate, bonefied SURVEY being 'national' land all around you.... They should give you a copy of it,so you can go find the 'markers' at all the corners of the land.....
BTW there's no GPS ( aside from milatary grade) that will be accurate.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 6:09pm
from a legal perspective the boys are right, you need a certified survey done. That said, surveys are expensive. The first thing I would do is buy or borrow a good GPS and use it to see if you can find any pins or stone markers. GPS should get you pretty darn close to finding them, if they exist. borrowing a metal detector might help. If the Feds are logging, they or the loggers should have their ribbon markers up by now. If your "unofficial" survey agrees with them, problem solved. If not, then you need to hire a surveyor.
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 6:17pm
yea, the GPS will get you within 6 ft or so... If you dont have "too many" trees in that strip then its not a big deal.... you could put up a few posts along where you THINK the line is and see if they stay on their side.. If they think you are off 50 ft then THEY need to get a survey done. ........ working for the STATE i would ASSUME they had everything marked before hand ?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 10:22pm
Find your line then spray a red dot on every tree that is on the border on your side.  If they cut any, they pay to replace it with a like tree.  Loggers are not likely to encroach when they know the costs.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2020 at 9:38am
somebody needs to have a CERTIFIED  survey done! ---THAT clears everybody hands down!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2020 at 11:36am
Not US Forestry but the Neighbor at Salem, decided was time to Log where marked a Line for himself well onto BILs place We had a survey and had located Iron Rods during the survey(Truck Axles) we had placed when initially surveyed.  So we Re-marked the line with Purple NO TRESPASS Paint.  logger came in supposedly had BIG Argument as to the line as to the Purple Paint then the neighbor tried to pull the Iron Stakes.  Bad Choice as another neighbor that also relied on those markers caught him.  Far as I know that fight is STILL in court between those two, BIL lost NO trees.  Been surveyed five times I am aware and Iron Rods are STILL The Corners, the Idjit is determined to get that changed but nobody has helped his efforts.
Edited by DMiller - 05 Aug 2020 at 11:37am
