WD-45 Hydraulic Pump |
Post Reply ![]() |
matt5569 ![]() Bronze Level ![]() Joined: 21 Aug 2010 Location: Missouri Points: 17 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Aug 2010 at 9:03pm |
My WD-45 is starting to leak quite a bit from the seals on the control box on the back side of the hydraulic pump. Leaks right at the seals where the linkages go in. I was hoping someone could tell me if it's fairly easy to get the seals and to replace them. I've never messed with the pump/control before, don't want to mess it up anymore than it already is, but I'm getting tired of buying hydraulic fluid! Thanks, Matt Edited by matt5569 - 28 Aug 2010 at 9:06pm |
Chris/CT ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
You should be able to re-seal that pump easily, parts are available.
Post Reply ![]() |
