AC HD6E Engine Oil
MJ2Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ2Farm Quote  Post ReplyReply Direct Link To This Post Topic: AC HD6E Engine Oil
    Posted: 03 Aug 2020 at 6:46am
Just recently acquired an Allis Chalmers HD6E. I believe it's a '69. S/N 70C22259.
The engine oil dipstick is not original. Can anyone tell me the dimensions on the dipstick to the operating range marks so I can make one? And how many gallons it should have?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 7:23am
crankcase capacity is 10 quarts + filters so could vary a bit depending on if you have HD bypass filters etc.  I would guess any dozer application with deep pan 344 should be the same dipstick  but would try to get measurements from a later direct inject engine to be sure.  I have one in a grader but its not a deep pan so may be different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ2Farm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 9:25am
I do not have the heavy duty filters on mine. Reading through the different manuals here:
Crankcase plus filter is specified as 2.5, 3, or 4 gallons depending on which manual you read. Plus an additional 1 gallon for the heavy duty filters.
The manual that I believe would be closest to mine is "HD6 operations manual for serial #13222 and up" which specifies 4 gallons for crankcase and standard filters. But that manual also specifies 5 gallons for the transmission and I definitely just poured 15 into mine so I'm not sure if I should go with what it specifies for crankcase or not since it was so far off on the trans fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 9:31am
strange.  my book says 20 qts for the 5 speed which is what the E is
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 9:39am
15 gallons for the trans dont sound right.... 5 really is a better number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ2Farm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 10:05am
Well I guess I'm concerned now...
I'm very mechanically inclined but this whole heavy equipment thing is very new to me.
I checked the level (dipstick appears to be factory) with the engine at idle and transmission in neutral. Kept adding until it was at the top of the operating range which was definitely 15 gallons.
Are the brakes/steering clutches dry on some models and wet on others and would the fluid capacities be different?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 11:06am
being a late model you probably have wet brakes and steering assist so you may be correct as they all use the same oil (from transmision sump) and would require more, but 15 gal sounds like a lot.  my book doesnt cover everything and the 20 qts is likely trans and bevel gear.
Edited by CAL(KS) - 03 Aug 2020 at 11:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ2Farm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 12:32pm
I can confirm it's power assisted brakes and steering clutches.
I drained a lot of fluid out of all three drain plugs under the transmission. I wanted to have a better understanding as to what was going on in there so as a test when I filled it back up I put the center plug in and left the two others out. Right about 5 gallons is when the two other holes started leaking. So I put the other two plugs in and filled her up... after another trip to get more oil. LOL
Any other opinions on crankcase oil capacity? or dimensions on the dipstick for my machine?
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 3:19pm
yours is a late HD6E; totally different to earlier ones.
crankcase capacity HD6E  20784 up is  4 gallons
transmission steering clutch housing is  15 gallons; use ATF or a 10W transmission oil.
There is filters on each side behind the battery boxes. Also a suction screen on lower lhs of gearbox.  If you have sluggish steering that is first place to look.
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ2Farm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 3:47pm
Awesome, thank you!!
I'll measure out 4 gallons and put me a mark on the aftermarket dipstick that came in it.
I did replace to two filters. How do I get to that screen?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 4:24pm
Use 10w Hytrans Oil in trans/clutch refill, I use a commercial grade, ATF is only for extreme low ambient temps.  Same system as on my 7G.
Edited by DMiller - 03 Aug 2020 at 4:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ2Farm Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 6:10am
Thanks! I did use hydraulic trans oil.
