Hauling CA
ddlong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Topic: Hauling CA
    Posted: 02 Aug 2020 at 12:26pm
Purchasing a CA in KS and need to know what is required to not get pulled over traveling back home to IA. Besides making sure everything gets back without incident!
Borrowing a car trailer and pulling it with my 99 4WD 1/2 ton Suburban.
Never hauled anything before so thought I would get some experienced advice.
Don
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 12:33pm
That's a long trip for your first haul.   Have you got a brake controller on your Suburban  to operate the trailer brakes?  As far as the tractor, just a four point tie down, front and rear, with good binder straps or chains.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 12:36pm
Well it's not as heavy as a big car..but... I'd have 4 chains + binders, one per corner. Be sure tires hold air !!! One went 'flatish' on me,so chain/binder got loose.
Clean it if possible..no loose dirt,stones, tree branches...
Put it in the 'sweet spot' so enough tongue weight but not too much.
Other will know more....I haven't hauled anything for 5 years..
Jay
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 12:39pm
You shouldn’t have any problems with DOT. Law is 1 chain per corner. So two chains on front two on back. I always crossed the chains. By this I mean attach chain to right side of tractor to the left side of trailer. Use a binder to keep chains tight. Load so rear axle of tractor is above axle of trailer with front of tractor facing the front of trailer. Just be smart and start braking early. Be safe and have a great trip!
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 12:45pm
As a CA weighs under 10,000 pounds DOT will not require a 4 point tie down on a CA.  1 chain going forward and another rearward will keep you out of trouble. Around the tractor in the middle of the chain with each at a corner of the trailer.  As for binders on 1 each chain will meet DOT requirements.  As I was taught many years ago; Put the binder on the right side.  If you have them on the left and need to stop on the road and tighten them down again, you'll be standing out in traffic. much safer to to be working on the right side of the truck/trailer when stopped along the highway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 1:41pm
Ratchet binder or lever?
No trailer brakes.
Thank you for the help!
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 2:18pm
Without trailer brakes be VERY VERY CAREFUL and allow plenty of space between you and the idiot in front of you. You don't want the trailer and tractor passing the Suburban. I refuse to haul a tractor or car on a trailer w/o brakes, they greatly decrease your stopping distance not to mention if you were to lose brakes on the tow vehicle those trailer brakes might just save your butt. BTDT. As Larry said that is a long haul for your first time. Don't try to go too fast but if the trailer starts swaying accelerate out of it and then slow down. Make sure the trailer wheel bearings and tires are in good shape and take a spare tire, jack and lug wrench.
I have always used lever binders but some inspectors prefer the ratchet binders. If I buy new ones they will be the ratchet type.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 2:21pm
I also haul our car on our trailer. The easiest way to tie a car down is to lasso the wheels. So that is also what I do hauling my tractors. But instead of using chains I use binding straps. They are rather inexpensive and you don't have to find a spot to hook to on the tractor.
Dusty
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 2:56pm
I've towed open and closed trailers with cars and tractors around New England for years. I'm no expert, but am happy to share my opinions!
I agree with using one chain (and binder) per corner. I wouldn't put a chain around the middle of the tractor - could put strain on parts not designed to take a heavy, sudden shock load.
I would NOT run a rig without trailer brakes and a controller in the tow vehicle. Can it be done? Sure. But you'll be in a heap of hurt if you need to stop quickly and that trailer starts to come around the tow vehicle....with no place to go and no time to do it in.
Edited by Dave(inMA) - 02 Aug 2020 at 2:58pm
WC, CA, D14, WD45
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 3:00pm
I use regular car tie downs on my CA & 2020d when I haul them and I haul one of them at least once a week. Get the weight over the axles of the trailer not all the way forward. 4 straps at least. The two in the front pulling forward, the 2 in the back pulling backwards, do NOT run a strap over sheet metal go through front wheel slots & through the draw bar or hitch on the back. You can nail 2x4s in front & along side the front tires & in front of & in back of the rear tires. I generally use 6 straps total & NOT the cheap red ,yellow or blue ratchet straps I'm talking over the road flat bed straps. Be sure the tires on the trailer are real honest to god 10 or 12 ply tires not car tires someone has put on there,be sure the bearings have been packed with grease. Its summer time and those bearings & tires are going to get HOT.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 3:27pm
I just looked at your second post,, no brakes??? Don't do it your asking for big trouble. That CA with ballast & if equipped with weights or an implement could easily weight over 5500 lbs.just sitting there,that same 5500 lbs running along at 70 mph is a whole new ballgame. After 45 years of trucking I have seen way to many times how that ends up
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 4:18pm
I say you need brakes on every axle just from the hauling I've done over the years.  The distance you are talking isn't just a couple miles down the road at home where you might creep along.  Also, you better check the laws for at least the state the trailer and your vehicle  are registered in regarding trailer brakes.   There is at least this info I found in a quick search, that would cause me concern legally, if something should go wrong on the trip.
"Indiana Trailer Brake Laws
A trailer or semitrailer that weighs at least 3,000 lbs. must be equipped with brakes adequate to control the movement of and to stop and to hold the towing vehicle and trailer or semitrailer.
These brakes must be designed so that the driver of the towing vehicle can apply the brakes from the towing vehicle itself and adequately stop both the towing vehicle and the trailer or semitrailer."
And while two chains or straps might cover the law, one on each corner is cheap insurance and will get less scrutiny if you do get checked.  It will help as well if all your chains or straps aren't DOT approved or grade 70, or better, in the case of chains and hooks.  Ratchet binders are better and safer than over center binders.  JMHO
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 4:32pm
Some states have band the over center binders. Any trailer with 2 or more axles must have operating brakes on minimum of 1 axle. Any single axle trailer with 8 lugs must have trailer brakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 5:15pm
"Required Equipment
If your trailer and load weighs more than 3,000 pounds (1-1/2 tons), it must have brakes on all axles. They can be self-actuating if the combination is less than 10,001 pounds combined GVWR, or brakes you can apply from the towing vehicle. On certain combinations of over 10,001 pounds combined GVWR, self-actuating surge brakes are allowed depending on the GVWR of the towed unit.
Drawbar and Chain:  When towing another vehicle or trailer, the drawbar must be connected to prevent side sway. Safety chains must also be used to connect the trailer to the towing vehicle.They must be strong enough to hold the load in case the hitch breaks."
Edited by Jim.ME - 02 Aug 2020 at 5:17pm
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 5:27pm
Lots of direction in the tie downs, brakes, etc. I’ve hauled my B’s and a CA ( all wo ballast, weights, etc. wo brakes on my car trailer and with my f150. Guessing Kansas to Iowa will be on I-35, so relatively flat, good highway. I’d run around 60 and let em pass you. That said, I now run an f250 w trailers that have brakes.
If your CA is narrow front, you’ll want some ramps for the middle of the trailer.
Where in KS and IA?
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 5:29pm
Lots of direction in the tie downs, brakes, etc. I’ve hauled my B’s and a CA ( all wo ballast, weights, etc.) wo brakes on my car trailer and with my f150. Guessing Kansas to Iowa will be on I-35, so relatively flat, good highway. I’d run around 60 and let em pass you. That said, I now run an f250 w trailers that have brakes.
Where in KS and IA?
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 5:34pm
Yikes NO BRAKES... pass on that trailer ,fast !!!
I hauled a caddy, locally and it wasn't fun. IDIOT drivers...WHY the guy changed lanes then STOPPED at the yellow was 'wonderful'. He was the luckiest S-O-B though, as I didn't get out of my truck.....I came close though...
ANY trailer over 2990# here in Ontario MUST have working brakes.....
..THAT answers why so many dealers have singles and tandems !!! rated for 2990#, so THEY don't have to add brakes and battery backup  features !!! Go figure.. a trailer with 2 - 3500# axles and it's  legally rated for 2990# !
Sorry for the rant but up here FINDING what's LEGAL for trailers is a nightmare.....
You 'might' be able to rent a Uhaul, one way but CHECK first ! Up here they ask what you're hauling...say a tractor and NO they won't rent, say 'a67 mustang ' and it's 'yes sir..do you want fries with that'..... sigh....
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 7:56pm
Uhual has dual axle trailers you can rent for a car or garden equipment that has brakes built in the tongue and does not require a brake box. I think you need to look at the weight close as I believe you will be around 3000k without the trailer. I would do the 4 point tie as it is safer for you with less experience hauling that load.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 8:31pm
Make sure the trailer gvw is under 10,000 --otherwise hope you have a cdl in your pocket ( check your laws there,--Here I have to have to have cdl to use my dump trailer behind my Explorer since trailer is rated 16,000 pounds)---other than that go for it! ---- I have done crazier chit and never killed anybody or wrecked anything! --- Take your time get the feel of it then find your comfy speed and keep it there. chain it down good and they wont bother you!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 9:37pm
Call ahead and make sure the tire ballast has been removed.  You definitely don't need the extra weight to pull or to stop.
Angle your front chain toward the rear to the front of the tractor and your rear chain toward the front, to the rear of the tractor..
If you have lever binders, I carry a 3' piece of chain link fence post to snap the binder.
Drive 5 to 10 miles after loading and then stop to take a look at your chains to make sure they are still tight.
I usually take a clevis to hook to the drawbar and run the rear chain thru it.
When you connect the chains on the trailer, if the trailer has stake pockets.  Drop the chain down thru and then bring it back up the outside and hook it on the pocket.
I always leave the tractor in reverse.
I carry a small jack stand to put under the rear of the trailer.  It holds it up when loading.
Take a spare tire, 4 way lug wrench, and utility jack.
If it's a narrow front you don't really need  a third ramp.  Drive up to the trailer at a slight angle.  Drive the front tires up the far side ramp and then brake and swing the tractor around to run the rear tires up the ramps.
I usually run 65 - 70 but then, I always have brakes.
Try to level the trailer.  Not to much weight or too little weight on the tongue.
DON'T forget the trailer is behind you and pull over in front of someone!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 10:10am
Just make sure that all of your lights and brakes work. Iowa requires all trailers with 3000 lbs rating and up to have working brakes on all road wheels. That said, I seriously doubt the DOT will look at you twice on the road.
This page was generated in 0.254 seconds.
