Gleaner E Hydraulics
Matt4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt4 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E Hydraulics
    Posted: 02 Aug 2020 at 8:22am
  I have been going through my combine getting it prepared for picking corn. I raised the head and pulled it out of the shed with no issues. Now the corn head will not lower nor will the variable speed pulley.
 Linkages are working. The valves are moving. Not sure what the problem is or what to look for. Any help would be greatly appreciatted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 8:24am
You have the engine running full throttle ??  Is the belt on the hydraulic pump ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 8:54am
Yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 9:10am
Are you sure the power steering works??   If not, maybe the pump ate its pigs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 9:36am
No power steering on this model.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 11:37am
Safety drop down on the corn head cylinder? Probably not with the variable speed not moving.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 12:00pm
just used my E in wheat. ----- Make sure the little res. is filled to the line with type A trans fluid.
Block up the head and check the pump for output pressure---if good then its stuck valves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 9:24pm
Sounds like you raised header, using all the oil in tank. Takes pressure to unseat poppet for header to lower. Or poppet in header valve broken. VS could be stuck.           MACK
