200 Temp Gauge |
Post Reply ![]() |
Red Bank ![]() Orange Level Access ![]() Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Aug 2020 at 9:27pm |
I bought a new coolant gauge and sending unit for the 200. Not really sure how to wire it up. Old gauge had two terminals + and -. New one has three terminals one marked 12v and the other ones negative. When I hook up the hot wire from the fuse to the gauge at the 12v post something pops in the switch and I lose power to the fuse. Not sure what’s going on but the main question is how to hook up the new gauge.
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
12 volt from the switch ign. terminal. The minus to the sending unit. Should only have power with switch on.
If it pops at the switch there is a short somewhere.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21919 |
The third connection is to go to a ground. It is DIFFERENT than the original design.
Post Reply ![]() |
