WC oil pump screen
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: WC oil pump screen
    Posted: 31 Jul 2020 at 6:11pm
Is the screen on a wc oil pump necessary any more? Having trouble getting the wire that holds it on tight enough to hold it on without breaking the wire. New engine and everything is clean on the inside.
Thanks, Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 9:21pm
I would not want to run without one.          MACK
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 9:28pm
I agree with Mack...get you some soft wire that size and then you can easily wrap the wire around the oil pump to hold the screen on, then twist it with a pair of pliers gently, until it's snug on the pump...easy to do.   Rick
Edited by Rick - 31 Jul 2020 at 9:29pm
