How many acres per hr
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: How many acres per hr
    Posted: 30 Jul 2020 at 8:08pm
Hi everyone.
Does anyone have an idea how many acres per hour a 200 with four bottom 16" model 2000 plow can do. Probably be in 2nd low. It has 34" rears on it. And it's level ground and its sod, hay field. Thanks for the comments in advance
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 8:20pm
I find the monoframe plow speed sensitive,,,I pull 6 16 with my 200 38'" rear tires 3 low and that is as fast as the plow wants to go...to do a nice level job that is,,, and not wide open, more like 2350 rpm or a bit less IIRC
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 8:38pm
2 1/2-3 ?? Been a LOOONG time since we pulled 4/16's with a D 17 Wink .
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 10:05pm
Amos, you must have sand. I pull 5-16 with 7050.         MACK
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 10:13pm
where i live farming plowed ground costs you dearly!   In your area it must not!
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 10:46pm
MACK you are correct sandy ground, plow very little actually, just to get rid of a hay field...used to pull 8 - 16 on land with 210 dual 18.4 x 38 in 5th ...heavy alfalfa had to drop to 4th, would carry front wheels all the way down the field
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 4:59am
4-14's on a D-17.   fully mounted.   did a decent job but carried the front end.   Plowing cost me tons and tons of topsoil, when it rained!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 7:05am
Plowing up terrases is all I plow any more.         MACK
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 7:59am
If your AC 200 can average 4mph plowing speed, then theoretically it could achieve the following;
Length is 4mph x 5280’/hr = 21.120’/hr.
Width is 4bottom plow x 16”/bottom = 64”(5.33’)
Acreage is 21,120’x5.33’/43,560=2.58 acres.
That doesn’t include any headland turn travel time, And, the 4mph is after wheel slippage being factored in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 8:05am
2nd low max speed with 18.4-38 rear tires is 3.9mph. So not going to make anyway near 4mph with 34” tires in 2nd low. Might though in 2nd high?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 8:33am
By the time I did headlands, turns, dead furrows, wedges on weird corners, etc., I always figured on about 2 acres per hour on average to get a "whole field done" with 4 16's. Though while going on the straight is faster than that, the inefficiencies really add up.
Edited by Tbone95 - 31 Jul 2020 at 8:48am
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 8:43am
We always figured about 2 acres per hour with 38” & running 3rd low on small fields ~5 acres. Make a little better time when fields are longer. Try not to plow that much now and burry the disc deeper if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 5:28pm
Thanks for that info, I was beginning to think that I was "off" on my memories as to how many hours were spent turning over  35 acers back then WinkWink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 7:45pm
Thanks guys. Hate to say this is for the enemy. One of the fields we bale is getting developed and they asked for a price to plow twenty foot sections every fourty feet.
wlambs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 6:23am
my dad taught me ground speed times width will give acres covered in 10 hour day. always works out pretty close. i have used over 40 years.
185,6080,6060,72 allcrop, roto baler
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 7:23am
Amos. Do you still have the 8 x16" on land A-C plow ? That is a rare piece now !
I have a 7 x 16" on land semi mount model 3000 mono frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 8:15pm
4 bottom plow will most likely be a mess with 20ft length?? That is some short lengths, smaller than a garden. Do you know why they may want it plowed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 9:40pm
Hi Kevin
It's 20ft wide skip 40ft then another 20ft wide across whole field. It's so they can do a archeological study. See if any Indians are buried
Edited by Mikez - 02 Aug 2020 at 9:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 12:11pm
Sounds like a big mess of the field when finished!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 9:52pm
Yup pretty much.
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 9:40am
And what if they're all in the 40' unplowed strips of land?
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 12:37pm
Hi Kevin
Where do you live?  Around here they just throw up houses, no archeological study required.  One place we rented got sold to a developer last year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 9:09pm
In New York
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 8:49pm
Here's a picture. Wish got picture of tractor in action.
Edited by Mikez - 17 Oct 2020 at 8:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 9:46pm
MikeZ, that’s a great looking farm. Love the fall colors. Thanks for sharing.
Edited by AC7060IL - 17 Oct 2020 at 9:47pm
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 8:01am
Too bad it's being developed, another farm lost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 8:51am
Mikez, how did you get the "lands" so straight ? Impressive job WinkWink ! Thanks for the picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 4:24pm
Practice, practice, practice.  OR, maybe a GPS?
NICE job Mike!  Glad you're out and having fun!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 4:38pm
There has been no "plowing" done "here" in this area for at least 20 years. 5 years ago a BTO attempted plowing 1 fall with I assume were "steering wheel turners", the end result was "not" a pretty sight as far as level/straight furrows, let alone what the dead-furrows looked like CryCry .It's becoming a lost art I'm afraid Confused.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 8:17pm
Howdy Mikes I’ll agree with Tbone95 on regular jobs but on those strips prolly you’d do better
Blue Skies and Tail Winds
                          Dana
