Tractor horse power
mhankins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Topic: Tractor horse power
    Posted: 30 Jul 2020 at 8:13am
Does any one know how the horse power of a tractor engine is figured compared to other engines?
 For example,my lawn tractor has a 22 hp engine,compared to say an Allis G rated at 10 horsepower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 8:32am
horse power is a CALCULATED number... You take the motor TORQUE which is a measured TWIST of the crank shaft output, and multiply by the motor RPM and then divide by a constant number ( 5252) .................. that result is the "horsepower"...... if you want a small motor ( lawnmower) to put out a LOT of HP, you get the RPM up (3600 RPM) .... A lager motor may put out  50% more torque, but if its MAY SPEED is 1800 RPM it will end up with less HP ............. and HP is not CONSTANT... Your mower is 22 HP at 3600 RPM... the G HP is at less than half that speed ? ........ so the G has sugnificantly more TORQUE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 8:35am
That is how you get a motorcycle or outboard motor to get high HP... You design the motor to run at 7-8000 RPM.......... while a bigger displacement tractor might run 18-2400 RPM ..... or 1/4  the speed.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 8:48am
Thanks Steve, I learned something new or should I say thanks for making me feel stupid.LOL  Had to try it on a torque curve/ horsepower curve chart on a tractor brochure I had and by damn it was almost spot on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 8:55am
What you will see is the TRACTOR has a lot of TORQUE at 1000 - 1500 RPM so it is a PULLER.... What you see on a motorcycle or outboard ( or chainsaw / 2 stroke) is that they have SQUAT at 1000 rpm, 2000 RMP, 3000 RPM... you have to hit 5000 RPM before the motor comes to life..... small displacement motors need a LOT of RPM to make up for NO BOTTOM END TORQUE..
LIke the old saying goes, there is NO REPLACEMENT FOR DISPLACEMENT...   BIG MOTORs LUG at low RPM........... Small motors need HIGH RPM to get the HP.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:04am
If you're interested, this is where Steve's constant comes from:
1 HP is defined as 550 (ft-lbs)per second.
1 Revolution is 2 Pi Radians (remember those?)
There are 60 seconds per minute.
So:
Torque (ft-lbs) x RPM x 2Pi Rads/rev x 1 min/60s x 1 HP/550 ft lbs. = Horse Power
Radians are "dimensionless". If you arrange all the multipliers (550 x 60) / (2xPi), = 5252.11, which you "divide by" in Steve's method.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:12am
"1 Revolution is 2 Pi Radians (remember those?)"
I dial in my scopes and shoot using minutes of angle, not milliradians. Wink  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:25am
It's all good!
The reason it is radian based is: Degrees (minutes and seconds) of angle is the relative directions of 2 lines to each other. Radians are how far around a circle you have gone, and it's all about the rotation in an engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:30am
Now i am confused ! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:33am
another good example is pulling a trailer... lets get a 3000 # trailer and connect to a D17 with 50 HP and a 4 cylinder motorcycle with 100 HP......The D17 you rev up to about 1500 RPM and let out the clutch slowly and walk away.....TORQUE.......... The motorcycle you let out the clutch and it dies... BUT, if you REV it up to 7000 RPM and let the clutch out SLOWLY it SHOULD pull the trailer..... and SMOKE the clutch ! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 11:33am
notice this on my 2 dump truck engines
6-200A White engine rated at 400 cu in - 200 HP at around 2800 RPM - 450 Lb torque
425 GM engine has no power at that RPM and doesnt develop anything until over 4500 RPM
Old White will cruse down highway empty at 80 MPH even with 6:38 gear ratio,
GMC has a hard time making 65 at 4500 RPM with 7:28 rear
For brute force the White engine will pull almost anything with torque and 5x4 transmission in lower gears - not fast but moving .
GMC is all noise and watching the gas gauge drop
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 12:02pm
gmc must have that not-so-great 366 or 427 in it! LOL!!!!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 1:09pm
Yes the old saying with a GM engine was slam the door on your hand and get in and drive like your mad at the world.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 2:59pm
The old scream-n Detroit's, lots of gears close together or your going no where. Can't lug a 2 cycle.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 5:11pm
with respect to what Coke said above, torque relates to how much work can be done, HP is how fast you can do that work.
Torque is setting on your Red Ryder wagon at the top of a hill, potential work capability, depending on how high the hill is. HP is going down that hill, and how steep the hill is. The work will be the same, but the steeper the hill (RPM) the faster it will get done.
I am still confident of this;
Wait for the Lord;
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 5:59pm
The lawn tractor's ENGINE is advertised as 22hp.  The TRACTOR is rated at 10hp.  There's a BIG difference.
Let's do a basic analysis of the circumstance:
Your lawn tractor engine says 22hp on the top of it's shroud, and if it performs as advertised, at the speed it's advertised to do so, under the atmospheric conditions that it was designed and set up for, the crankshaft will feed that 22hp to whatever it's connected, for as long as the engine's designed performance lifespan was intended.
When you engage the blades of your mower, the engine slows slightly, and the throttle opens.  This happens because the blades are thrashing through the air, and it takes horsepower to do it, so your horsepower at the edge of the blade will be a little less.
In the same realm, engaging the driveline includes driveline losses, so there'll be a little less horsepower available at the drive too.
Let's arbitrarily say that blade drag consumes about 4hp, and that driveline losses consume about 3hp... that means you've got 22-7= (did everyone get 15?)
Now let's look at how that power is actually used...
The machine needs to move around the yard.  At the reduction levels the lawn tractor uses to generate a walking pace, with my 215lb weight, the driveline will need practically no power (mebbie 1.5) on flat ground... only about 4hp to climb a 5% grade.  Bump it to 15%, and you'll need closer to 8hp, but after that, it won't matter, as the machine's turf tire will not generate enough adhesion to successfully climb.
The deck needs to cut grass.  Let's say the deck is a 46" three-blader, with good flow characteristics and sharp edges on good (meaning, better than mine) dry grass.  It will require about 10hp to run that deck through modest fescue at a fast walking pace.  Thicker grass at same will require 14-15hp instead.
How much power did we have left?  Ah... 15hp.  Which makes perfect sense- if you ask it to climb, and cut really thick grass, fast, it'll bog... so you 1) slow down  2) cut going downhill, and 3) make a half-cut pass going uphill.
Now for practical limitations:  With this lawn tractor, you will NOT be able to get 22hp of PULLING power.  Why?  First off... agricultural traction is a function of tire diameter (rolling resistance) and a ratio of weight on driven vs. undriven wheels.  With no rider, there's about 120lbs on the front wheels, and mebbie 80lbs on the REAR.  With agricultural traction, a soil traction tire, on soil, yields around 18-25% traction coefficient... meaning... drawbar FORCE will only be about 18-25% of the DRIVE TIRE weight, LESS whatever drag occurs with the FRONT wheels (not driven).  With only 80lbs on the back tires, you'll generate what... 30lbs of tractive effort at the drawbar?  Not much.  Sit on the tractor, and now you have 215+80= 295 on the rear wheels, and if you place your drawbar high, it'll lift the front wheels, and you'll have 295+120=415lbs so about 120lbs of drawbar pull... IF the tires don't start slipping on wet grass.
But wait- that's not all...
The transaxle in your lawn tractor... if it came out of a '60's through '80's IH Cub Cadet, it'll be strong enough to transmit enough torque to the tires to provide all that (and more), but if it's a die-cast zinc belt-driven 'module' held to the sheet metal frame, it'll litter your yard with sharp glitter and promptly stop, before getting anywhere NEAR that capacity, so...
You won't be getting 22hp worth of power pulling anything.
Now let's look at how an Agricultural Tractor is rated:
NOBODY 'rates' a tractor ENGINE.  A 'power unit' yes, but a 'tractor' ENGINE, no.
Tractors do work, and that work is done either with a belt, a PTO, or a drawbar.  Hence, their ratings are based on those loads:
Belt HP  - Measured by a dynomometer at the BELT PULLEY.
PTO HP - Measured by a dynomometer at the PTO SHAFT.
Drawbar HP - Measured by a drag sled, with strain gauge, distance measuring apparatus, and a TIMER.
Of course, there's some obvious limitations here... if the BELT used for the FLYWHEEL test is inappropriate, insufficient length, or not drawn out properly, it might not be able to transmit all the tractor's power to the dyno.  In the same way, the tractor's TIRES may not be able to provide enough tractive effort to make use of the engine's power potential, so it 'spins out' before getting to a respectable load level.  The latter can be improved upon by adding weight (agricultural traction is highly dependant upon weight, remember?  If not, search for, and read the Wismer-Luth Agricultural Traction Prediction white paper published decades ago...).  Like the lawn-tractor, if the back wheels spin, but the tractor doesn't move, that means there's engine capacity left, but the tires can't put it to the ground.
NONE of these measurements have anything to do with ENGINE rating... because regardless of HOW the engine is tested, it MUST be able to generate MORE flywheel horsepower, to accomodate ALL losses (like gearbox friction, power steering pump, alternator drag) as well as accomodate environmental conditions (like fuel quality, ambient temperature, pressure, and humidity) as well as DUTY CYCLE... and perform that way within the manufacturer's advertised Mean Time Between Overhaul (MTBO).
The engine in your Allis G is a Continental 69CI flathead.  Using quality gasoline, It will generate around 22-28 hp at the flywheel under average circumstances.
Placing it under extreme conditions, it EITHER engine might be able to do as well, but frequently, extremes will limit the machine's ability.
OFTENTIMES, the engine's limitations will be found not to be in crankshaft horsepower availibility, but instead, on DUTY CYCLE... meaning, it'll work at some level HIGHER than rated horsepower, but for a LIMITED duration of time.
Hint- Liquid coold motors are frequently MUCH more capable of running above their 'continuous duty' limits, for longer, than an air-cooled equivalent.
So the key to realize, is that if you're buying a big-box 'lawn tractor', the 22hp might mean 15hp worth of deck, comparing it to an Allis G will be a case of comparing apples to deer pellets.  The Allis G will pull, AND run PTO, and climb through things a 'lawn tractor' will simply not... and it all goes back to a basic situation:  Agricultural tractors were built to replace HORSES, so a 2-horse plow would be best matched to a 2-horse team, or a 2-horse tractor.
And from another perspective, if you want to determine how many horses it takes to trim your lawn, just put up a fence and let them graze...  but... watch your step. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:06pm
Thanks for the explanations.
 You would think the tractor manufactures would rate them by torque instead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:18pm
torque would be a good way to rate a motors output at any given time, but everyone forever has related to Horse Power..work you can do over TIME... HP takes into account the RPM capability of a motor... 100 years ago when everything ran at 900- 1500 rpm that was  OK ... Now that motors ( motorcycles etc) run at 9000 rpm, the HP values are FUDGED for comparison to a tractor motor ( 1800- 2500 rpm).
The term HORSE POWER was used as WORK FOR A DAY to compare to an average horse at the time.. The motor does not get tired after 8 hours... the horse does.
Therefore the term "horsepower" may seem slightly misleading, but Watt did have his reasons for such a name. When Watt made his improvements to the steam engine, he understandably wanted to convince people to buy it. If he said that his expensive engine had the same short-term output as a horse, people wouldn't buy it, as they already had horses. Instead, he compared it to the amount of work a horse could do in a day, giving it the output of ten horses instead of just one.
Edited by steve(ill) - 30 Jul 2020 at 9:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 9:58pm
Not sure about all this horsepower and tractors, but when I was a young man I thought I was 10 horse, now that I'm older I'm positive that I'm less than a 1/10th horse. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 11:22pm
Torque isn't the whole story, either.
Work = force * distance
Power = Force * distance * time.
I could take a 3hp Briggs engine, put enough gear reduction behind it to develop a half-million foot-pounds of torque, but it'd still only be a 3hp output... because of TIME.
And furthermore... a half-million foot-pounds of torque, going into a 300lb chassis with 16.6.50-8 tires, will NOT have any substantial value in drawbar force... it's just not heavy enough to create tractive effort.
Duty cycle!  Let's say a kid takes his imported squash-bug car, and puts twin turbos on it, and can get it to squirt a chassis dyno to 350hp.
Tie the car down really tight, have him bring it up to boost, dial up the dyno to 350hp, and walk away.
How LONG will that engine run, before it becomes a baptismal font of hot aluminum all over the shop floor?  Three hours?  An hour?  20 minutes?
Now take a big Cummins tractor engine that's advertised as a 350hp powerplant... put it on a dyno at 350hp, and go on a 10 week vacation.  When you get back, it will STILL be churning out 350hp.
The industrial/agricultural rating assumes a 100% duty-cycle circumstance... it will not overheat or self-destruct at that power level.
Ag/industrial ratings are not 'under-specified'... they're spot-on.  Automotive horsepower ratings, however, are mis-stated, because the DUTY CYCLE is intentionally left out.  Why?  Because it takes you 8 seconds to pass somone on a 2-lane road, and after that, you're driving a little over the speed limit for the next 18 miles....
Post Options Post Options   Thanks (1) Thanks(1)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 9:47am
Shetland pony, myself
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 10:55pm
Funny you should mention Shetlands, Lou-  James Watt based his power unit description on ponies used in mines of England and Scotland... they were energetic little fellers, but not in the same realm as my grandfather's Percherons...
Yesterday, as I was climbing the south driveway with a load on the forks, I realized I'd left off an important point that is alluded to in other's posts, but an excellent example:
That 22hp lawn tractor engine, in order to produce that 22hp, had to be running at it's governed speed.  In order to climb my hill with the load I had on my back forks, it would take considerable gearing-down of that air-cooled motor.
My D17, although not generating it's full horsepower, I had it throttled way down, in first and high-range, to ascend gently...
Because the D17's front wheels were barely touching the ground.
But it climbed with no drama.  The engine was probably generating 20hp at best, but at idle speed, thus, it was all very placid, smooth torque.
When running a tractor, it is not a common thing to use ALL of it's output potential.  It is very often that the tractor needs to run at some less aggressive speed, in order to stay under control of the task-at-hand.  This is what is referred to as 'tractible power'... you don't have to fidget or fight with the machine to get the job done, the machine is more than capable of doing it at slower crankshaft speed, thus, flexible to the circumstances at-hand.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 4:30am
There is a Youtube vid of a Farmall H with a 6 hp Harbor Freight engine doing actuall stuff. Slow but doin. I think there's a Minni Mo too.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 7:16am
Is it this one?
[TUBE]qeS60YwMDAo[/TUBE]
A 13hp repowered Massey Harris 33 plowing.
[TUBE]CWMPdYwjpY0[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 9:26am
Yeah, I don't think I could live with that for any length of time, but it would be fun               to mortify your neighbors with.
Edited by Walker - 04 Aug 2020 at 9:31am
This page was generated in 0.250 seconds.
