Starter Solenoid Malfunction
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Starter Solenoid Malfunction
    Posted: 28 Jul 2020 at 11:32pm
Is there any way to fix a starter solenoid that won't engage the bendix plunger? I jumped power from the battery terminal to the start terminal and it just hums a little bit. Is the only solution a new solenoid?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 5:57am
 Hey Creston,,,good to hear from you,,,you been havin so much fun elsewhere you ain't been here,,,,Wink
 It depends which kind of solenoid you got. I have taken apart the GM style solenoids and rotate the contacts inside and make em last another 50,00 miles but the fender mounted styles like the Fords use are not repairable. As a rule, the solenoids either work or they don't. The humming may be an issue with the brushes or a short of the armature to case ground. I'm not much help,,,,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 7:58am
there are two studs on the solenoid.. If you JUMP them together, the bendix should pull in and the starter spin.... if all you get is a HUM, you have additional problems with the bendix / starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 8:56am
Ford style ... drill out the 4 rivets, 'dress' the contacts or flip over, use 6-32 N+B to reassemble the unit...
the 'trick' to ALL solenoid reapirs is to be 100% sure the contact MATE totally flat...
alway wondered how big a cap you'd need to quench the inrush current arc. I suppose that's on the web somewhere.......
Edited by jaybmiller - 29 Jul 2020 at 8:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 8:58am
Yeah Steve I can jump the two studs and the starter will take off spinning, but the bendix doesn't pull in.
Hey Joe! Yeah I been busy on a custom harvest crew, but I'm back now. Haven't been able to log on much in a while.
It is on a Ford engine, but it's a Lucas starter/solenoid.
Edited by CrestonM - 29 Jul 2020 at 9:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 10:12am
loks like a 'use once-buy another' style unit........sigh
I'm guessin $200 ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 10:49am
Looking around on eBay, the solenoid is $40, and a whole new starter with solenoid is $111. I guess it's a pretty common unit, used on most of the Ford thousand series.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 11:10am
Wink Oh the good old days back in the 80's NH swather with a Ford 172 diesel.LOL Nice running engine if you could get it to crank with the Lucas starter. Finally found a local rebuilt that worked pertty well.
If you been having trouble with hard/slow starting Wink go whole hog and replace it all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 11:16am
The AGCo replacement is a gear reduction non Lucas, work like a champ!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 1:31pm
If I have that problem I will. I haven't got the engine to crank at all yet, since the bendix hasn't been kicking in. Trying to get this thing running, and it's been sitting since about '92.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 1:55pm
so the bendix is part of the solenoid ?
You know that LUCAS was called the "PRINCE OF DARKNESS" for the last 80 years for a GOOD REASON !!  If there is an alternative as DAVE said, it might be worth it !
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 2:28pm
If you can get the solenoid off the starter (you may have to pull the starter to do it),  You may be able to pull the plunger out of the solenoid.  It might be dirty, or rusty from setting, and cleaning an a light wipe with oil well make it go.  The Bendix might be stuck on the shaft and not moving as well.  Have you tried tapping, in a technical manner of course, on the solenoid and rear of the starter housing behind the solenoid while trying the starter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 2:59pm
www.brillman.com has a NEW LUCAS solinoid like that for $2795 for one that fits the M45G, M127, M418G starters, Part # B5007-017. Another one for the M50 starters, part # B5007-018 for $34.
The Brillman company is the only place I go for anything electrical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 8:44pm
That's a good website, Paul! Mine must be the M50 starter, because that's the solenoid that was on mine.
Jim...I've got it off the machine and tried all of your suggestions. No luck. With the solenoid off, I can reach in and move the linkage with 1 finger, and the bendix slides smooth as silk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 9:19pm
Sounds like you need a new solenoid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 9:44pm
I agree. I ordered one, so it should be here Monday. If the starter gives fits down the road I'll put in a gear reduction starter.
Thanks guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 11:34pm
o-k Creston.....soooooooo...where's the pics from the harvest crew/travels? what crew you on? and i hope you are NOT running around the country with....(gasp) green seeders?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 1:07pm
Hey Shameless! I was with a guy named Mel Gossen, a big-time Gleaner guy from here in Oklahoma....I wouldn't consider going on a green crew! As to photos...his policy is no hired workers are allowed to carry electronic devices in the field (causes wrecks and other mess-ups), so no cell phones, etc. But my Polaroid isn't electronic....but I can't readily post those photos here, and I only took 3 or 4 with it.
And the old Gleaner reputation continues...at the elevators they told us several times we had the cleanest wheat. He runs four 2016 S97s, and they have definitely proved their durability. I heard they've ran approximately 2,000,000 bushels total of wheat, corn, milo, and lentils through each machine. Replace a few wear parts occasionally, and they just keep going!
Edited by CrestonM - 30 Jul 2020 at 1:10pm
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 10:44pm
they usually have a pull-in and a hold winding, pull not doing the job, hold is 'humming'
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 11:01pm
whew...thank the Lord! i was worried for a bit you know! you tells yer ole boss...us Gleaner folks on this forum...WANTS PICS!
This page was generated in 0.344 seconds.
