D14 headlights
ACCURT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACCURT Quote  Post ReplyReply Direct Link To This Post Topic: D14 headlights
    Posted: 26 Jul 2020 at 12:29pm
I'm in the process of converting my D14 from 6 volt to 12 volt, and I am needing new headlights. My 6 volt bulbs are a sealed beam that measure 4 3/4" round and are held in with a lock ring wit a screw tightener. I can't find a replacement for this bulb. Does anyone have a source? I did find a glass lens and reflector that uses a replaceable bulb that looks like it might fit. Is that the only option?
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 1:03pm
Steiner Tractor or All States have them I believe.
D17 Series 1
Allis B- 1939
Allis B- 1945
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 1:07pm
The D-10 series III came from the factory 12 volt, it's a sealed beam Part #230252.
Will it fit ? I don't know. Could measure mine.
Dusty
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 5:26pm
If your 6v sealed beam have two connectors.  Run 12v to one connector, run a wire from the second connector on that bulb to one connector on the other bulb and a wire from the last connector to ground.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 9:56pm
D14s after serial number 19001 are 12 from the factory.  Those head lights are 4 1/2" in diameter.  I got a couple from the AGCO dealer and wrapped black electrical tape around the lip that the ring goes around.
You would never notice by looking at it.
