Heck of a deal??? Maybe
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Heck of a deal??? Maybe
    Posted: 24 Jul 2020 at 4:10pm
A coworker bought an Echo CS590 chainsaw. Used it one time. Now it won’t start. He was mad at and sold it to me. Says it hasn’t sat long. Gas smells good. It’s getting gas.
Any guesses??
It looks like brand new.
I gave him $100.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 5:35pm
Check the plug for foul then check for compression, did the gas smell like gas or mixed fuel?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 6:58pm
 OH Gosh,,Thad,,,Lets not be alarmists yet,,,so,,Lets hope this one works out in your favor. Could be any number of things. Like ole Dave says,, could be a bad spark plug or a bad coil,,I've seen both even with almost new small engines. China just doesn't  yet have a good track record with the magnetos/coils for the small engines, I know for a fact. One of the best buys I made was a "Coil Tester" that you insert between the spark plug and the spark plug wire. Pull the rope and if coil is good, you can see the spark flash in the little window. If no spark, check the on/off switch, those are notorious for going to ground. If you don't have a spark checker,,,,you might have ole "little ??" (can't remember his name),,have him hold onto the coil wire while you pull the rope for a sure test,,,,,,WinkWink
 (don't tell him I said to try this method)
 Let's hope the PO knew to mix oil in the gas if a 2 stroke as it will not take more than bout 5 minutes of run time before the cylinder is cooked. My fingers are crossed on this one,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 7:12pm
I can’t seem to get lil Vernon to grab or do anything any more. He’s acquired some sort of trust issues for some reason.
Took it to the shop. Pulled the plug. It was soaked. Used the ole ground the plug method and it has spark but blue and weak. It actually ignited gas that the piston squirted out the plug hole.
Tried a used plug from a different saw with no luck.
Still on its first tank of gas. Gonna dump it and start fresh tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 7:18pm
gas ?? no should be a 2stroke joke right ?? be sure to mix proper ratio !!
if the cap say 40:1 mix 40 to 1 NOT 30:1, 55:1, eyeball amount....
Might be worth the cost to buy the proper premixed fuel (hitest + oil)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 8:25pm
Couldn’t take it. I went back to the shop. Dumped the gas. Blew out the tank until dry. Pulled the fuel filter and cleaned. Blew air in fuel line from a distance. Pulled the plug and blew air in cylinder. Cleaned/dried the plug. Put all back together and she fired second pull. Closed choke and running on 3rd pull. I cut a few pieces of wood to help run some gas through. Ran perfect.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 3:51am
Last visit to farm I discovered the Stihl would not even sputter even with fresh gas. Brought it home and pulled plug. It was wet. Checked and no spark. Pulled off kill wire on coil and still no spark. Seems to be a common problem, bad coil. Ordered a new coil and that got it. About $30 with a new plug.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 4:53am
 Say there, My Friend,,,,you startin to get like ole Joe with your share of them "Good Luck deals",,,,Clap And I'm glad for you,,,!!  Ms. Jenn will most likely be cookin you your favorites today,,,,ClapClap You'll be able to tell her HOW much money you saved on HER chainsaw,,,,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 5:54am
NICE !! sounds like a winner !!!
I got rid of 2 gas saws last year..fed up of the PITA...as I didn't use them often and have 'carb/gas' issues. Now that I've sold next door...less to worry about. I do have 3 electrics though(1 pole saw,others 14-16" bars) they always start !
With today's lousy gas, maybe we're supposed to 'run until empty' ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 6:37am
I try to use only non ethanol in small engines.
My old Stihl didn’t want to run last time I tried it . Finally got it going but was some work.
This is a much bigger saw than my others. Don’t know weather to keep it or sell.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 8:02am
I replaced temporarily my O26 Stihl with an Echo CS 590. Nice saw,no issues so far as I cut most of my firewood with it last year. Haven't had the time to rebuild the O26. May get to it this winter.Still sets on the shelf in the shop!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 8:18am
Can use general pump gas so long as mix MINIMAL for use, use that up run saws and weed trimmers until stall out then clean ALL the gas out of the tank, I then add a stabilized mix of canned gas to each little engine start and shut them down.  Canned mix gas lasts a long time, the general gas if used up becomes no problem.  Know others that just run the last of season tank with a little stabile in it then run them dry, also not having issues,
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 1:34pm
I like my battery power chain saw pull start button and it's running when battery is read for a recharge so am I
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 1:47pm
One of my Husqvarna's was real particular on gas. More than a couple months old and it wouldn't run. The others can be going on a year and still run.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 3:24pm
Each brand is different as is each model!-- some are super picky !
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 9:11pm
When I found myself in the market for a chainsaw, I did a little research first which was when I found out that the old AC saws were made by Poulan. Since an AC saw in running condition is well beyond my comfort zone price wise for an occasional use saw, I took a chance on a brand new 16" Poulan saw sold through Lowe's at the time. I was quite satisfied with it as a homeowner doing storm cleanup on my and my in-laws property for many years. It always started every time that I needed it no matter how long it had sat. As far as fuel, I used the same 87 pump gas that I run in my mowers but with the proper oil ratio mixed in. This same gas can also supplies my weedeater which has been fine for many years now too. Unfortunately, I made the mistake of leaving my chainsaw sit outside on the porch 1 night after using it and somebody walked off with it. Needless to say, I will have no problem buying myself another Poulan when I get another saw.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 6:01am
Thad,
 Good deal. Yes you had compression, (new saw) you had sparky, So the fuel would have been what I would have suspected too. This spring I had several things that had to have fuel drained and changed out to get them to run. Sounds like you got a nice saw for about a third of the price of a new one!
 Awesome! Now where are the pictures?
Edited by Sugarmaker - 26 Jul 2020 at 6:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 6:51am
Thad,
I phone no work with this forum. Several of us have tried.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 7:25am
iPhone, I had to try! Rotation wrong, but it worked!
Edited by Tbone95 - 26 Jul 2020 at 7:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 7:30am
Nice deal on the saw! Sounds like the owner just fouled the plug. Maybe he forgot to turn it on for several pulls, or maybe the switch can be iffy, or maybe the fuel was a bit off. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 7:33am
And a great pic at that. Reminds me of my younger days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 7:39am
Reminds me of 3 weeks ago!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 7:43am
 Hey TBone,,,tell me "exactly" how you got your IPhone to transfer the pic on here,,,,I've just bout give up with my IPhone 8,,it just6 WILL NOT transfer to my PC,,,,
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 8:22am
Try emailing to yourself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 8:57am
I was (am) logged on with my iPhone. Do you ever do that?
As for transferring to your computer, it “should “ work easily, but if not try emailing it to yourself. The pic should then be able to be saved anywhere on your pc
Edited by Tbone95 - 26 Jul 2020 at 9:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 9:49am
I only have the phone now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 10:04am
I got chewed out for making loads like that. The girls unloading didn't like getting the top bales down....lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 10:43am
Boss man, I got to unload it myself, so... I don’t very often make them that big due to tires, ease of unloading, steady work flow for helpers, etc. But when we started, I said I want one more big load this year before we round bale the rest!
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 3:49pm
That is a pretty stack! I broke out in a sweat just looking at it! I always preferred loading rather than unloading, it was mighty hot in the hay mow and no breeze.
That is a pretty stack, tight, real even, etc
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 3:57pm
Edited by Tbone95 - 26 Jul 2020 at 3:58pm
This page was generated in 0.336 seconds.
