Motorcraft Or DriveWorks ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Motorcraft Or DriveWorks ??
    Posted: 20 Jul 2020 at 5:58pm
Needing to replace #8 coil in a 5.4 F250 (worst one to get to) Confused. Local parts  place has has OEM Ford for $58, or a Driveworks brand for $40. Anyone  have experience with the lesser $$ version ?? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 6:03pm
My guess is they're both Made in China, same factory, and have the same lousy nonwarranty ( electrical part).
I've heard coils go often though never why.... funny(not really) that  we've got 40 year old lawnmowers still runing with original coils.....
I'd check the warranty especially if it's a nightmare install.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 6:04pm
I have bought a dozen off e-bay ( 5-6  years ago) for $10 EACH.... Get a SET for $75.  I was needing a "replacement" about once every 12- 18 months.. Had a 5.4 from  2003- 2018.
Takes about 10 minutes to change ONE coil, so i never worried about LONG TERM.
Edited by steve(ill) - 20 Jul 2020 at 6:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 6:14pm
Thanks for the reply, but if you can change-out # 8 in 10 minutes or less, I'll vote for the current POTUS (NOT!!) Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 6:20pm
Thanks jay, it happens to be the WORST possible cylinder to get to CryCry
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 7:05pm
its not that bad.. #8 is more HID in the back, but there is only 1 screw to remove.... Actually takes more time to do #5 or 6 because you have to remove steering pump bracket....... I had two F150s over 15 years and put put 250K miles on them... Not uncommon to have a coil failure every year or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 7:20pm
Bring your truck to me, I'll change it it 10 mins or less, guaranteed! Sat**day!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 7:35pm
2  minutes to get the step stool and tools, 2 minutes to get the air cleaner ducting out of the way, 1 1/2 minutes to R@R, 2 minutes to replace ducting, 1 1/2 minutes to clear the code, 2 minutes to put tools/stool away ConfusedConfused ?? Am I close ??
Now this is with me pulling into your shop with the engine still STEAMING hot, you can't take minutes off for your "patties" to not get singed WinkWink.
Edited by FREEDGUY - 20 Jul 2020 at 7:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 8:11pm
I am using Bosch replacements from Rock Auto. Got 2 in the tool box just in case. They can be a pia to change, especially for an old fat man like me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 8:21pm
Thanks Hubert , and ALL of the above posters Wink. That's my handicap, a larger-than-I_ care to admit belly, and the fact that I'm not "comfortable" with digging into an area that I can barely see into LOLLOL. Thanks again guys !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 8:22pm
Thanks Hubert , and ALL of the above posters Wink. That's my handicap, a larger-than-I-care to admit belly, and the fact that I'm not "comfortable" with digging into an area that I can barely see into LOLLOL. Thanks again guys !!
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 8:33pm
You could try replacing just the boot, if you can find them. I discovered sometimes it's not the coil/ but the boot braking down.
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 8:47pm
Lou, the boots and plugs have less than 9,000 miles on them Wink, to my knowledge, other than the 2 coils that got replaced at the dealer a month ago and 1 that we found during the plug/boot replacement, the other 5 are original, 170,000 miles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 10:03pm
another one of fords "better idea"?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 10:17pm
We been buying used ones from our local salvage yard. Always keep 4-6 of them in a box behind the seat.   Dang V10 usually eats 1 every couple of months. Getting low again. Gonna be going by the salvage lot on Wed. Should stop In and pickup a few more.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 10:22am
I wonder why the coils they built years ago would sometimes last for the life of the vehicle??  More lost technology??
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 8:28pm
To those that "stock" coils, how do you know which one ('s) to change ?? Got the buggy running great for now, took ALOT longer than 10 minutes and it's been a long time since I've sliced 3 fingers and the backhand open, plus a sore rib leaning over the radiator/ps pump LOLLOL . I could not IMAGINE what it's like working on a van ConfusedOuch !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 8:38pm
$50- $100 CODE READER....... Code P0301 is missfire #1... code P0302 is missfire #2 .... missfire does not always mean BAD COIL , but that works 90% of the time.
Some younger guys use an APP called Torque Pro that they download onto cell phone or computer and need a special cable to connect... Can do that for $20..... but im not tech savy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 8:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 8:47pm
Thank you for the reply Steve Wink. When I ran Dodges, I could "toggle" the key switch to get the C/E light to put out a "morse code" that could be deciphered by the auto parts store SmileSmile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 9:38pm
YEP... thats "old school" as the kids say... I use a Code Reader and they think im  way past OLD... You got to have a IPhone with an APP that talks and draws graphs and, and , and.... i told them when it changes spark plugs for me, SIGN ME UP !! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 6:45am
just wait.... some 'engineer' will put TWO plugs in every cylinder and 2x more coils so you'll have 4x the fun of changing stuff.....LOL
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 10:33am
  Wink  Always fun to have optimist in the bunch.LOL
Edited by Ray54 - 22 Jul 2020 at 10:37am
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 9:19pm
Something to that effect.  The technology lost, was of the engineers who knew intimately how the coil did what it did, and how it was best made to survive it's function in the underhood environment.
Most infatuated with 'new tech' label me a Luddite of sorts, when it comes to the experimental whiz-bang of today, but the reality is, that they're ignorant of the technology proven by those generations before.  An industrial engine of 60 years ago seems whimsical to those of modern-disposition, but due to a short-sighted construance of 'tech', those same critics fail to recognize the amount of development and proving that allowed something to be simple, robust, and reliable.
That being said, I'll note that the magneto on my 1956 Hercules JXLD generator was given a rebuild by John Boyens ONCE some 16 years ago, and it never misses.
In contrast, I've had spark-ignited Fords since we ditched the PowerStroke 4 years ago, and in our 8-truck tech fleet including V10 and V8, we've had at least 76 coil-on-plug units replaced. and 11 spark plugs blown out of aluminum heads.
The 'official report' is that there is 'nothing wrong', which means such failures are now considered 'normal'... therefore, failure is apparently accepted as 'normal'... the only thing that is apparently 'wrong', is simply that this has yet to be incorporated into any official company slogan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 5:59pm
Thanks for the reply Dave, but IMO, the "76" is about "70" too many and I would be jumping ship Confused WAY too much aggrevation for "me" that runs this truck for me to take time off for "diagnosis/repair/$$$$". Never dreamed that a USA manufactured product was such a POS Ouch !!
