Allis Chalmers D17 Series IV industrial or not
Allis Forever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Forever Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D17 Series IV industrial or not
    Posted: 19 Jul 2020 at 8:43am
Hey guys. The allis addiction is growing again and I’m back up to but I think 1 might be selling to a friend who needs a tow tractor.
So I picked up a D17 series 4 as I wanted the factory style 3 point and use it with my modern implements vs the 1 snap coupler implement I have
I am giving her a well needed clean up, tuneup and probably valve job and started noticing a lot of yellow under the orange. It’s a 64 with a serial number somewhere run the 75-76 thousand range. The engine number is appropriate and coincides numerically with other d17s I had and I believe it is original to this machine
Does the engine number and or serial
Number show a letter I anywhere if it was a yellow tractor/industrial.
I will try to attach photos.
Any info is appreciated
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 9:06am
Its been discussed before and I believe the yellow was the primer they used
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Forever Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 9:07am
Thank you. Ok that makes sense as there doesn’t appear to be any color below the yellow
