shuttle clutch |
Post Reply |
groundhog55
Silver Level Joined: 26 Apr 2011 Location: nw in Points: 217 |
Posted: 17 Jul 2020 at 7:23am |
I have a D15 diesel with shuttle clutch. I tried to pull start it, because I cant get it to start with starter. Thing has set for years. Rebuilt pump and checked injectors. Will not turn engine over. Is it because of shuttle clutch or is the engine clutch screwed up?
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20493 |
Place shuttle clutch lever fully forward. Place transmission in 4th gear. Hold foot clutch pedal DOWN and pull the tractor about 6 or 7 MPH. Dump the foot clutch. If the engine doesn't turn over, it is stuck. When you are pulling the tractor while in 4th gear and the shuttle clutch ahead and foot clutch fully down, you are turning everything inside the tractor except the engine.
groundhog55
Thanks: I'll see what happens.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7332 |
Make sure the engine isn't stuck first!
Post Reply | |
