Valve Clearance ?? |
| Author | ||
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Valve Clearance ??Posted: 11 Jul 2020 at 6:51pm |
I have a close friend that bought an Audi 4 cylinder engine car(I don't know the year) that broke it's timing chain and incurred MAJOR valve train damage
| Sponsored Links | ||
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3985 |
Posted: 11 Jul 2020 at 8:14pm |
Quite a common thing with today's engines. Many have the cam or cams driven by a timing belt which is supposed to be replaced at a certain mileage. Failure to do so will sometimes result in a broken belt and if it's an "interference" type engine, much damage can result!! I don't get that type of "engineering " either.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 12 Jul 2020 at 7:29am |
[QUOTE=FREEDGUY]
It's known as "Planned Obsolescence"
Engineers plan for things to break to boost sales of new vehicles and repair parts and to justify their existence designing the wheel over and over again. Luckily The engineers at Allis Chalmers were not of that mindset, however Henry Ford has been quoted that everything should not last any longer than the warranty. When everyone was making Jeeps for WWII he wanted ever single part that left any of his factories to have the "FORD" logo imprinted onto them so he could not be charged for replacing something that some other place made. |
DrAllis
Posted: 12 Jul 2020 at 7:53am |
Not any different than some older technology V-8's that have a timing chain and fiber camshaft gear wearing out. I have seen bent valves from that happening.
plummerscarin
Posted: 12 Jul 2020 at 3:01pm |
I discovered the hard that at least the 170 is an interference engine. |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35684 |
Posted: 12 Jul 2020 at 3:21pm |
Only engines that were truly Non Interference and Not designed for that reason, flatheads. Any diesel engine breaks a cam drive or a valve hangs in a guide looking at severe damage.
FREEDGUY
Posted: 12 Jul 2020 at 4:48pm |
My friend did say that "only" the exhaust valves got bent (8), but he replaced ALL 16. Why would only the exhaust valves get damaged
DMiller
Posted: 12 Jul 2020 at 5:15pm |
Engines tend to be on Down stroke for Intake, Up stroke for exhaust, belt breaks, gear fails and most times the intakes are already closed/closing. Not much momentum on a cam to keep it rotating.
FREEDGUY
Posted: 12 Jul 2020 at 5:41pm |
Thanks DMiller
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25259 |
Posted: 12 Jul 2020 at 5:49pm |
Why do 'engineers' design stuff like interfernece engines ?? Because they get paid to AND THEY don't ever have to work on them ( or PAY to have them fixed) !! We could (should ?) have a forum devoted to 'engineered booboos', 'cept it'd take up ALL the space on Darrin's harddrive !!
FREEDGUY
Posted: 12 Jul 2020 at 6:03pm |
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Thanks(1)
Posted: 12 Jul 2020 at 8:25pm |
Dave you're right about messing things up when you break a valve. Broke one on a 855 Cummins. Got the head, turbo, two inj. one piston and liner. Made a terrible racket. Leon
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12420 |
Posted: 13 Jul 2020 at 7:24am |
Hmmm.....I'm no engine guru. But aren't there some very sound thermodynamic reasons for the "interference" design? Such as, to get the air/fuel charge at the correct compression, if there were more room at the top, there would have to be more air/fuel there to be at the same pressure. Then some things like air/fuel mixing efficiency in a larger volume. Seems a lot of interweaved little issues there.
FREEDGUY
Posted: 13 Jul 2020 at 6:15pm |
I was afraid that the "efficiency" (exhaust/pollution) might be a factor
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 13 Jul 2020 at 6:26pm |
ya beat me to it TBone, many, many times in my life I have said not nice things about the engineer who did this or that, but the reality is his job is not an easy job! There are a multitude of variables with just about any engineering task, cost, performance, appearance, longevity, size, weight, available materials, and, of course, marketing's wishes, to name a few. Yes, that engine could have been designed so that should the timing belt fail there would be no damage, but, at what cost somewhere else? performance? weight? complexity? initial production cost?
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 13 Jul 2020 at 10:04pm |
Yea, i have a 125 cubic inch Allis motor that weights about 300 pounds and puts out 20 HP..... using that same spec, you could build a 400 cubic inch truck engine with NO interference fit that put out a GOOD 75 HP !!!
Tbone95
Posted: 14 Jul 2020 at 8:13am |
More valves = more/easier breathing = more performance and efficiency. And yes, more "small" valves are better than just "bigger" ones. |
FREEDGUY
Posted: 14 Jul 2020 at 7:09pm |
Thanks Tbone
DMiller
Posted: 14 Jul 2020 at 7:16pm |
Cams are problematic, cylinder heads on the earlier 5.4s were a disaster where plugs seized hard in the head threads, required special tooling to retrieve and ended with a Plug change to another type. Do NOT ignore engine odd noises that start out minor then grow as the timing chain tensioners were also a issue. Pre 2004 were only 2 Valve, after 04 three valve, Triton has nothing to do with that configuration, Just a Name.
