7050, new steps (pics)
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: 7050, new steps (pics)
    Posted: 07 Jul 2020 at 8:26am
We'll see how this works.   We've had nothing but rain for July, so this was one of those "rainy day" projects while we wait to make hay this summer.
Two holes were drilled for the top bracket.
Reused bottom brace from original step and welded a threaded rod to fasten it.
Edited by Ron(AB) - 07 Jul 2020 at 8:29am
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2020 at 2:15pm
Looks good
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2020 at 7:22pm
Looks good Ron. Have you got the door shock kit on it. I put one on, and with the 8000 series step mine is so easy now to get into.
  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2020 at 9:32pm
Don't fasten steps to fuel tank!!!!!!!!!!!!          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2020 at 11:39pm
Mack, the old step fastened onto the fuel tank and it worked ok.
Have you seen trouble with this new step set up before?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 7:41am
Have saw a lot of tanks leak from step supported to tank. That is why later tractors had step supported from belly of tractor.        MACK
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 8:34pm
Cab is mounted on rubber and you mounted the bottom to the fuel tank with no iso mount
This page was generated in 0.273 seconds.
