eve trough
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: eve trough
    Posted: 05 Jul 2020 at 12:01pm
A lot of the grit/sand from the shingles on our house has washed into the eve trough, and on down and plugged one of the underground tile. There is still a lot of it in the eve trough.
The house was built in '95, we moved here in '12. I don't know if this is the first or second roof.
Has anyone seen this happen? Is this a common thing to happen?
Dusty
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 12:51pm
Both the Rectory (the priest house I live in) and a garage both had that 'sand' in them when I cleaned, along with leaf debris which made it a little like mud. I don't have to worry about any under ground tile...these just drain onto the ground... A N Y W A Y, I would say your problem is not unique.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 2:30pm
You can get Pat the Plumber to confirm but the reason the underground tile plugged is either a restriction or too much fall in the pipe.  If the pipe has too much fall per foot the water outruns the solids and leaves them behind to bunch up.  Industry standard for refrigeration drains is 1/8" per foot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 4:28pm
Is Eve Trough related to Virginia Pipalene?Wink
Edited by DiyDave - 05 Jul 2020 at 4:29pm
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 7:37pm
Dusty
Sadly, you've got multiple problems going on Cry. First, if you've TRULY got that much "sand" in your gutters, your shingles are SHOT!! Secondly, your "tile" is plugged with years of decaying leaves and/or plugged with tree roots, NOT the shingle granules  Wink. Chances are that it's the original roof IMO.
