Moisture Tester
BART View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BART Quote  Post ReplyReply Direct Link To This Post Topic: Moisture Tester
    Posted: 03 Jul 2020 at 7:08pm
Are the Dickey-John Moisture testers a good unit
I am talking the $100.00 Dollar Range Thanks Bart
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 7:54pm
They used to be. We sold a lot of them in the 70's at the local Coop.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 6:41am
No
Get a Dole 400 or a midsize GAC cheap tester aren’t worth more than a tire shock
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 6:50am
We have the ~400$ Dickey-John tester for grain and I have always thought it was reliable, get the same readings as the elevator. I would think the cheaper one should be ok with less functions? I just have a Vermeer stick tester for hay.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 10:21am
We have had a Dickey John M - 3G for...IDK, 10 years or more? I don’t remember the price. Guess that means I’m not much help. But FWIW, I always thought it does ok. Reads very close to what the elevator says, and you can easily bias the reading if there’s a consistent offset.
BART View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BART Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 11:06am
Thanks Everyone!!
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 11:11am
Ah, DJ, I used to work there over a decade ago... The mini-GAC was pretty good as I recall but they were several hundred dollars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 1:35pm
GACs aren’t cheap I bought mine with issues and had a factory redo on it. New they are $3000 plus.
This page was generated in 0.115 seconds.
