Allis electric 2500 MPH-RPM tach |
Post Reply ![]() |
Allis Fields ![]() Orange Level ![]() Joined: 17 Sep 2009 Location: Reedsburg,Wisc. Points: 332 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Aug 2010 at 7:46pm |
I bought a new nos allis tach there is 3 wire post hook ups on the back pos,nec and above them a 3rd post. I want to mount it on my pulling wd with a 1 wire alt. think this is for a combine. Any ideas?
norm [ind] ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
has to be late combine as the early ones were mechenical
CJohnS MI ![]() Orange Level ![]() Joined: 27 Jun 2010 Location: Lapeer MI Points: 326 |
pos to the dist side of coil neg to chassis ground 3rd term for lamp just my best guess |
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25236 |
Watchya' figurin on doing 2500 MPH on?
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
bigfish_Oh ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: West Liberty,Oh Points: 1226 |
Lou, everybody knows Allis did do projects for NASA
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe 1951 WD, factory p.s. 1960 D14 HnMk IV BkHoe 4 sale 2014 HD Tri Glide 2009 GMC CC SLT Dually |
Bee ![]() Orange Level ![]() Joined: 14 Jun 2010 Location: NC Points: 201 |
My engine analyzer tach has three wires. Pos to positive side of the battery, Neg to ground, third wire to lug on side of distributor.
Bob, North Carolina
1949 B |
BobH ![]() Bronze Level ![]() ![]() Joined: 19 Aug 2010 Location: NW Ohio Points: 17 |
Would early mech.tachs work on a D17?
can't post any pics yet computer at home still down. there is a light that has a wire going to the positive post.
gcalent ![]() Bronze Level ![]() ![]() Joined: 19 May 2010 Location: Willards, Md Points: 179 |
If it is for a late modle combine, it was made to work off of a sensor in the flywheel housing and counted notches in same. If this what you have it will not work on the inpulses from a distributor, also you need a tach that is able to calabrated for a four cylinder if you use one to the distributor. Most after market ones have seperate wires for 4,6,and 8 cylinder depending what you are going to install it on.
Pullin With AC
me spewed coffee reading that! |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12007 |
Most 3 wire tachs usually have a green black & red wire. (not sure on an AC tach) Shouldn't matter what Alternator you have....
Green- trigger = to coil neg. side. (with Neg. ground)
Black- ground
Red- 12V Ignition source
cbt1124 ![]() Bronze Level ![]() ![]() Joined: 10 Sep 2010 Location: New York Points: 16 |
I think that the tach you are describing actually was wired into the alternator not the ignition. .If you have a single wire alternator you can just throw that Tach away.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42010 |
Altenator on my 715B has another terminal on it for the tac. The regulator modual has 3 terminals on it.
Body is a 10SI but has this modification
Edited by Coke-in-MN - 10 Sep 2010 at 3:24am |
Post Reply ![]() |
