Brillion seeder
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Brillion seeder
    Posted: 25 Jun 2020 at 9:34pm
Hi everyone.
Does any of you have a brillion seeder, and know how to adjust the small seed box for smaller seed. I have a pretty good idea but just thought I'd ask.
Thanks
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2020 at 4:20am
Check for the manuals online at the Brillion website, even for the earliest units by model/serial number..  Mine is from the early 2000's and has a a 15/16" hex  the end of the shaft for the small seed meters. You catch and weigh the seed from a certain number of turns of the shaft. I use a triple balance beam gram scale, there are electronic versions too. My manual has the formula, but you can probably measure the drive, count the teeth on sprockets and create your own formula. Mine will get the rate within a few ounces per acre on the small seed box. The fluffy agitator should work the same way but has varied more from the calibrated setting to actual field rate. I think driving speed may influence this.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2020 at 5:01am
Make sure the rolls don’t touch a high spot or anything on your way to the field. Also come to a complete stop on the ends before you pick it up. If the rolls are turning your metering seed.   Started renting an Esch drill instead and much happier.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2020 at 6:17am
Mine has numbers on the hex shaft that corresponds to a number on the sed chart. You move the the hex nuts to move the shaft that adjusts the slides that allows the seed out
