D15 II Noise
D14JIM14 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Topic: D15 II Noise
    Posted: 25 Jun 2020 at 2:35pm
It has the usual final drive noise but there is a chatter coming from the bell housing area and when you push in the clutch it stops then starts up again when you engage the clutch . This just started . Throw out bearing ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 3:16pm
Hydraulic pump. You've got one of the levers clear up ??
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 4:00pm
Thanks ! Duh ! I forgot all about that noise . I'll check it out tomorrow . I did lift the 3 pt arms up . Been a while since I heard one make that noise .
