bolting carb to new manifold on my wd
Jaybird14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Topic: bolting carb to new manifold on my wd
    Posted: 23 Jun 2020 at 8:33pm
I just got a new manifold for my 51 wd.  it is a bit different from what is on there.  I have a Zenith carb and there is not enough room to get the bolts between the top of the intake flange and the body of the manifold. the flange is so thick even with shorter bolts i dont know if there will be enough threads left to hold the carb on.  Whats the solution??
Thanks!!
Jay
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 9:03pm
You will most likely have to put studs in the carb and then you will be able to put them up thru the  manifold with nuts on top of the flange.   Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 9:07pm
Or thread the manifold and install studs in it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 9:09pm
Thanks Den,
That's not the worst thing . It looks like 1/4 - 20 ??
The casting was kind of poor, i have already filed casting "flash" off the top of the flange.
I thought this would be a quick swap... lol.
Edited by Jaybird14 - 23 Jun 2020 at 9:15pm
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 5:06pm
Jay, nothing simple is ever easy. And the corollary is also true: nothing easy is ever simple.
Dave
WC, CA, D14, WD45
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 5:26pm
Poor casting, I got a couple like that, I sent them back.   Total junk, they were made in turkey if I remember correctly.  Got one from Steiner that was good to go.  All States Ag were the bad ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 9:05pm
mine is from Steiner.  who the heck designed it so the flange is too close.
i still need to file the neck above the flange so the nut can spin on the stud i made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 9:37pm
The sand casting was just not correct when manufactured.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 10:28pm
a little quality control would be a huge deal. I'll get it done lol.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 12:07pm
The parts books shows a stud in the carburetor. PN 70230917. I think is 5/16. Fine thd. one end, course on the other. Should be able to get at any auto supply.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 5:52pm
There supposed to be a stud both ends set the nut on the flange and screw the stud up into the nut then put your gasket and carb on with two more nuts the neck usually holds the top from turning thighten from the bottom. Threading wont work due to 5/16 Hole you would need tothread the manifold 3/8 then drill the carb 3/8 and think it would be to close to turn a bolt or nut
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 9:08pm
5/16 course thread screws nice into my carb.
I've cut two little threaded rods, screwed them into the carb, slid the stud carb combo partially onto the manifold flange. just far enough to get the nut started. tightened it all up.
after a pile of filing and cutting two studs all fits. lock tight will be a must.
i will start painting this weekend.
