F2 grain head
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Topic: F2 grain head
    Posted: 23 Jun 2020 at 1:52pm
Was there ever a 10ft rigid for a f2?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 5:03pm
September 1976, November 1977, & December 1978 sales literature all states F2 gleaner header sizes available as; 13', 15', 16', 18', & 20'
Edited by AC7060IL - 23 Jun 2020 at 5:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 9:47pm
Thanks, I would love to have a 10 ft on the narrow roads in our area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 9:51pm
Cut it down. Not as hard as it looks. I've cut several down.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 10:02pm
Would it be easier to put the mount from a 13 ft f2 on a k or k2 head?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 9:13pm
I always felt Gleaner could have made the K/F(K2/F2) 10’,12’,13’,& 15’ headers interchangeable. The A330/338 black cornhead was interchangeable(maybe A430/438 too?), but none of the cutter-bar platforms.
Swapping an F/F2 opening in place of a K/K2 opening shouldn’t be too difficult? But actually the F/F2’s lower openings heavy gauge metal transition is the only thing required. The K/K2 header’s top hook’s mount holes could be unbolted, slid out for F/F2, then it’s new mounting holes re-drilled/tapped, same with K/K2’s left/right vertical supports, cut down K/K2’s header drive sprocket shaft, but the K/K2’s lower transition would require a few added fabrication sheets of metal widening it to allow for F/F2.
Personally, I wouldn’t ruin any good F/F2 13’ header by removing its opening.
Of course, I don’t think the K/K2’s 10’ headers lower pan support frame would require widening? Might though for any wider headers?
Edited by AC7060IL - 24 Jun 2020 at 9:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 12:26pm
That's my issue also , the head I got with the combine is a flex and been abused. With a little love it will run and I only have a few acres of grain each year and could use a pull type but don't won't to store one. I try to keep my equipment in the dry every night and a 10 ft head would be a plus it seems. I sold the head with my k2 so I guess the search begins for a deasent 10 ft one. I'm going to try the 13 this year but likely will not be fun. If anyone has a useable 10 ft head let me know. Thanks
Mack, the head I got now is probably not worth the time and effort. Its so rough I have to wear goggles and gloves just to look at it!
This page was generated in 0.043 seconds.
