AC 175 D question |
Post Reply ![]() |
Author | ||
TomYaz ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: PA Points: 10335 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jun 2020 at 11:35am |
Does the power steering use the same sump as the rest of the hydraulics? I assume yes? If so, I assume the sump is shown here at the bottom with a pipe disconnected?
If I get the hyd sump buttoned up and filled, could I expect to move the front wheels with steering shaft even if tractor off? Its %100 hydraulic as far as I can tell, unlike my D17 ![]() Edited by TomYaz - 22 Jun 2020 at 11:37am |
Sponsored Links | ||
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21905 |
Steering is "hydrostatic" which means 100% hydraulic. I would not expect to be able to turn the wheels on that tractor. Some tractors will steer with engine off and others will not. All depends on how much internal leakage there is.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
I agree with the Doctor. I always wondered why some of mine would steer and others wouldn't. I had the steering motor on my XT rebuilt a couple of years ago when I was restoring it and it did make a difference.
Thanks...makes me wonder how the tractor is moved around for repair when cant start it...
Skidloader with forks under the front axle and pick it up. Chain axle loosely to the fork carriage so it can't slide off.
Seems a really poor design to have no way of turning wheel without power....neighbor has a tractor thats %100 hydro front end but even with power off he can get the wheels to turn
When this salvage yard 170/175 was new you could also steer it manually !!
Oh.. then I misunderstood what you said. So I can get it to steer. Per my previous unanswered question, does the steering hydro use the sump per my pic? My immediate goal is to get it under cover and take the head off and see what I am dealing with. Got to be able to move it.
Edited by TomYaz - 23 Jun 2020 at 11:09am |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5097 |
If it had been run recently, it likely would be able to steer a little bit with the steering wheel. But, when they've been sitting for years, there's little chance a hydrostatic steering system from and brand will work. There is a "closed loop" system built into it in case of loss of engine/hyds when driving, to maintain control.
I see...Is the whole hydraulic system closed loop or just for the steering?
ranger43 ![]() Bronze Level ![]() Joined: 09 Jun 2019 Location: Huntingburg Points: 154 |
x2 we have a 170 diesel we bought new and had to pull start it over the years and you can steer it with some effort if recently ran |
Only steering.
Thanks guys, good info!
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Actually the steering is open center also. The steering control is more like a metering valve. As long as it has enough oil in the system, the rotor will pump oil to the cylinder to steer.
I sense a disturbance in the force....
The whole tractor is an open center system, but when shut off, the hydrostatic steering system becomes a closed loop manual steering system for very limited use. There's a big difference in closed center, and closed loop system lol!
Post Reply ![]() |
