Square head nuts and bolts.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: Square head nuts and bolts.
    Posted: 20 Jun 2020 at 2:11pm
Am I the only one who doesn't have sockets for square head bolts?
The other day I got into a comical usage of an assortment of wrenches to work a square head nut. Use this wrench and turn, then flip over and turn a little then grab the other wrench and turn some, then back to the first and repeat.  Drop one, bump your head...
Hey it was hot and humid out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 2:29pm
12 point sockets work just fine on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 3:20pm
Your right Brian... 6 pt are worthless in this application. 12 point should work, but the OLD nuts normally have worn edges and not much to grab.. I normally TRY to use 12 point if i can get one that fits and dont slip.. They make 8 point for the square nuts and pipe plugs. I have a set of them, but you hate to spend much money if your not using them very often..
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 3:34pm
Heat them with a torch first, then toss some  squirtum on them and 12 pt will take them off most of the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 5:38pm
Heat is the miracle for breaking stuck nuts.  I know about 12pt sockets, don't have enough of them and most of what I get into will round off.
So do you replace with square head hardware to keep original look, or use whatever they got at the store (hex heads). You can go broke and batty looking for original style hardware.  Then even in hex heads, there is common usage in ag equipment of  the "heavy"  hex's, bigger wrench and thicker nut. Is it just me who tries to find the heavy nuts if originally used?
Maybe some day I will relax and be ok with using a nail as a cotter pin, and any nut and bolt that fits and so on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 6:03pm
McMaster Carr is the one shop I buy a lot of odd fasteners from otherwise use Fastenal locally.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 11:28pm
My craftsman set came with a full set of 8 point up to 3/4" plus i have a second set that came with the set my wife gave me back in 1981. I dont use them often but when you need one nothing else works. Ive taken down several grain bins that have square nuts. If you dont have a socket you wind up cutting many screws they usual have sloted head screws and square nuts
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2020 at 7:25am
I just bought this 15/16" square impact socket to remove the square bolts in the steel wheels of my (steel wheeled) B.
I thought the price was reasonable. Lots of Kroil, but I am still torching a bunch of the bolts. Not surprising since they have been run in the dirt for many of their 75+ years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2020 at 8:21pm
Back when I had the Ford tandem dump truck those inner and outer fasteners for the bud wheels required a square drive socket - ended up with a couple different sizes in impact sockets to take care of the tough square nuts / headed studs .
 Hub piloted buds are sure easier now
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2020 at 9:40pm
BrianC your talking about just for an example the correct nuts and bolts in the adjustable wide front on a WD45. When I got my 45 next trip to the tractor salvage yard I had to get the correct bolts to replace mine
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 7:04am
Brian,  Try Spaenaur in Kitchener. Can order on line. Have everything you can imagine in fasteners including original hood clamps for D series and chrome original style grill clamps for D-21 and hundred series.
fadouacommitment View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fadouacommitment Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 12:06pm
I don't think you're the only one. I didn't even have a socket for square head bolts some time ago. Moreover, I had no socket for other types of screws. When it came time to install the decking screws I ordered, I couldn't because I didn't have the right tools. So I had to order the whole set needed to be equipped for such situations in the future. Your solution is just as good, but it is much more convenient and safer to use a socket for bolts. I think so ;) So I recommend you to buy one. It will be helpful.
Edited by fadouacommitment - 27 May 2022 at 6:53pm
dee_veloper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dee_veloper Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 2:08pm
If it's for rare uses, try one of the universal sockets:
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2022 at 5:43am
I always found that those things were only good for making a nut into a round piece of steel. Never had any luck with them.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2022 at 9:14am
LOL  Yeah, round it off, grab it with a pipe wrench, and problem solved!
Square bolts and nuts made sense at one point in history, and every once-in-a-while, there's circumstances where they're necessary NOW, but the flippin' wrench/bump head/drop wrench routine stinks.  Having the head rounded-off (or in more cases than not, just corroded off) to the state that ANY wrench or socket won't grip, I use one of two tactics:
Hold a 6-point NUT against the head, and apply hot-glue (ER70S is my favorite flavor here) to the bolt head THROUGH the nut, until the nut holds itself on, allow the 'glue' to fully cure, then apply impact socket and electric gun...
or...
Apply enough heat for the offending fastener to develop a little red spot, then pull the magic trigger, and watch the fastener head vanish onto the shop floor, then use a suitable drift punch to drive the remains out...
I used to be young and patient... I guess I'm getting too damned old-and-grumpy for that, eh?LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2022 at 2:43pm
Ha, today it is hot and humid and I needed a HEX thin/jam nut, 3/8-24.
I headed out to find one with full confidence that no store around here would
actually have it. I was right! So aside from square head hardware, now they
don't even stock hex head. The lathe was employed to face down a regular nut. I got lunch out of the trip.
Fastenal left town. I do have a Mcmaster-Carr account, and they do have everything, but the shipping is always a shocker.
And last week my welding tanks went empty while cutting up scrap. Wonder what kind of new pricing they have on welding gases.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2022 at 11:03pm
Brian, that's the kind of day when we gotta say:
Somedays the dog...
Most days the Hydrant...LOL
This page was generated in 0.313 seconds.
