7580 fuel issues
Joe Goodwill View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Topic: 7580 fuel issues
    Posted: 18 Jun 2020 at 8:16pm
I have been left with a 7580 to resurrect. It’s been sitting for a couple of years. Turn on the key, electric fuel pump runs continuously, open bleed valve before injection pump and fuel shoots all over. Crank engine no fire no smoke. Crack injector line on pump and crank engine no fuel appears. ??? Looking for clues🤦🏼‍♂️
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 9:07pm
Metering valve stuck or pumping plungers stuck. Take top off pump and check metering valve.           MACK
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 9:12pm
Thanks do I need any special tools, seals or gaskets to take top off and replace?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 9:24pm
No, just hope none of the little bolts don't twist off. Don't need to replace, just free it up. If plungers are stuck, that is a rebuild.     MACK
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 9:46pm
Hopefully the easy one! Thanks
