Yellow Paint?
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: Yellow Paint?
    Posted: 15 Jun 2020 at 9:46pm
I just got an early D 17 and a 54 WD 45 and they both have some yellow paint. The 17 has the engine block yellow and rest AC orange. The 45 has the torque tube yellow and the rest AC orange. Looks like factory primer and not owner paint. No construction background parts that I know of unless parts swap sometime. Where did the orange go or where did the yellow come from?
I used to be young and stupid, now I am not young anymore.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 5:26am
My 17 had yellow under the orange. But not sure how the orange would fade to leave the yellow?
Charlie
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 5:49am
I have a B (with a belly mower and plow) that appeared to be yellow. When I was prepping it for paint, I found some orange in spots, but also found yellow in places that made me think it might be original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 8:06am
Yellow primer sealer on the outside and in the D-series and newer they painted the inside of the housings with yellow primer sealer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 8:56am
Remember seeing factory replacement blocks and other big components in uncle's dealership warehouse in the late 60's and early 70's, all in factory yellow primer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 5:47pm
Factory replacement parts makes sense to me.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 11:33am
Had an interesting thought- given the transition years of the WD45 and D17 and the comment of replacement parts being in dealer stock without orange paint, did they possibly leave parts unpainted in case the farmer had a tractor repainted in PO2 vs. PO1? I know there were many WD/WD45s repainted with PO2 and even cream wheels when the newer D-series came out, as farmers and dealers would "update" the look of older tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 1:45pm
Castings are porous and weep oil and probably coolant too. The primer/sealer solves that issue.
This page was generated in 0.617 seconds.
