any thoughts on what
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: any thoughts on what
    Posted: 15 Jun 2020 at 7:35pm
an eight foot bed from a 2005 Ford P/U would weigh? I'm figuring about 750
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 7:53pm
Thats probably MAX.... more like 500 pounds... I took a  6 ft bed off a 2006 FORD... Took the 6 floor bolts out and you could "almost" pick up one end by yourself... I parked under  open rafters in the garage and put a  1/2 ton comealong on the left front tie down and the right rear tie down and  cranked it up a foot to roll the truck out from under... put a 1/4 inch rope on the other two corners to rafters to BALANCE so it didnt tip too much.... mine was access to the gas tank pump....... then reinstall bed.
Edited by steve(ill) - 15 Jun 2020 at 7:58pm
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 8:01pm
Well under 500 is my guess. I’ve pulled a few with one guy on each side.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 9:35pm
Ask your local body shop.  Bet they can tell you within a few pounds.   Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 5:31am
500 maybe...less if the crossrails are missing due to rust......
I flip them upside down with forklift(A-C !) and 2 helpers to put onto pickup for transporting when sold.
5' forks  make it easy to remove and install.
Always 'interesting' how the wind 'magically' appears when moving the boxes....
so be careful !
probably moved 100+ in past 10 years.
Jay
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 3:10pm
My son, his wife and daughter and I picked up my 1975 Ford 8' bed and set it on so I don't think it was 500 lbs.
This page was generated in 2.773 seconds.
