1969 HD16DP f/r selector issue
Charly1067 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charly1067 Quote  Post ReplyReply Direct Link To This Post Topic: 1969 HD16DP f/r selector issue
    Posted: 15 Jun 2020 at 8:49am
I finally got this 16 running last night after sitting for 8 years,but I cant get it to go into gear. I can select forward or reverse but cant pull the lever back to 1st or 2nd gear. Is this a frozen linkage issue? Or do I have bigger problems. Also the blade raise and lower lever is froze up. Any advice would be helpful.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 1:37pm
I know nothing of your transmission,but since the blade control lever is froze it seem reasonable that other linkage is stuck as well. So start spraying your favorite lub and wiggling and tapping on things to get things moving.
This page was generated in 0.149 seconds.
