WD & 45 Head swap?
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: WD & 45 Head swap?
    Posted: 14 Jun 2020 at 4:11pm
I have a WD and a 45 that could use the WD parts. Just put lots of bucks in the WD head and now have a 45 that needs engine work. Can I move the WD head to the 45?
Thanks, Larry Miller
I used to be young and stupid, now I am not young anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 9:43pm
Yes, as long as you use rocker arms and ect. with head.           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 10:03pm
Thanks, that is good news for me.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 7:55pm
The heads on the later WDs were the same as the WD-45; 4" tall.
Only the early WDs  (prior to "engine" serial #289001) had the "short (3") heads.
If the WD head you intend to use is the "short" one, only then will you have to change the rocker arm stands and pushrods as well.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 5:28am
Pushrods remain the same.  Rocker stands, valve cover, and head studs are all you need to change.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 6:44am
Thanks Aaron for correcting that, I knew that.....just forgot.
Short head, tall rocker arm stands......Tall head, short rocker arm stands.
Oh, and the valve covers are also different too, tall for short and short for tall.
This page was generated in 0.441 seconds.
