P/U Rear Axle Fail ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: P/U Rear Axle Fail ?
    Posted: 12 Jun 2020 at 8:12pm
I drove past a yard this afternoon that had multiple "cones" along the road up to a parked p/u and flatbed trailer. I just assumed that some type of landscaping work was being done until I got closer Confused, the rear driver tire/wheel was UP a foot into the wheel well at a 45* angle and protruding outwards at least 10"s and the bumper (drivers side) was on the ground Cry. This happened to be a 3/4 ton chevy about 8-10 years old. Any idea of what might have happened to the poor guy?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 9:22pm
Broken lug bolts from the gorilla on the impact wrench or the axle broke where it comes out of the axle housing.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 9:54pm
They used to have a big snap ring on the inner end of the axle. At 3-400000 miles they sometimes wear out. The axle will move out like you said. I do not know it the later units had the same design.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 11:19pm
If it is a full floating axle, Hubert is probably correct. If not, could be either Tom or Hubert's guess. 3/4 ton, probably full floating
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 11:21pm
Someone forgot either the square cut key, or the snap ring that holds it in. Those AAM rears have a big retainer that threads on like a nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 8:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 5:39pm
Thanks guys. All I know is I felt bad for the poor guy, it looked like pictures of the CIH 2300 series combines with their r/h drive tire at "cab level" Cry
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 8:29pm
His first mistake was buying a Chevy!!! LOL
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 8:37pm
I prefer ABD! anything but Dodge
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 7:58am
BILs 2000 GMC K2500 is NOT a full floating rear axle, flange type like a half ton, Weight packages can be light or heavy dependent of model type and year to get a full floater. That said I see all manner of self determined home mechanic do brakes on full floating axles and never pull a hub, bad idea as to inspect the bearings is almost a necessity as badly as we abuse light trucks these days, if brakes are shot that means a great deal of heat delivered to the hubs and bearings where the grease never really fully recycles to the rear end.
This page was generated in 0.234 seconds.
