The Plastic/Foil Oil Jug Seal ?? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: The Plastic/Foil Oil Jug Seal ??Posted: 10 Jun 2020 at 6:20pm |
Sadly, I topped-off the 5.4 last night with a pre-opened jug that had a "hang tag" remnant left on the lip that sure-as- SH*T fell off and into the fill port
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 10 Jun 2020 at 6:22pm |
If it makes it to the oil pan, will probably get stuck on the suction screen INTO the pump... Stay there forever.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 10 Jun 2020 at 7:22pm |
It will catch in the first place that has a smaller passage then it is. Years ago my Aunt cooked the motor in her car when her Auto Mechanic son topped of her overflow tank and let a piece of the foil fall in. It would let Anti-Freeze into the overflow tank when the car warmed up and then would plug the outlet when the car cooled off, thereby not refilling the radiator. That little piece of foil will still be intact when the next Ice Age comes.
HD6GTOM
Posted: 11 Jun 2020 at 5:43pm |
I had a guy bring me his wife's car, he did the same thing. We pulled the pan, Plastic was sucked up to the oil pump screen. Probably would never have hurt anything. He didn't want his wife to know he dropped it.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35690 |
Posted: 11 Jun 2020 at 6:05pm |
Working HD Trucks saw LOADS of those on pickup screens in oil pans and the tin seals for Fuel additive in tanks or stuck in fuel lines/filter heads. Know several guys use it as a extra spill control valve to load the bottle neck into a fill tube then squeeze the jug to get flow, One wiped a engine with doing that.
Edited by DMiller - 11 Jun 2020 at 6:05pm |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25262 |
Posted: 11 Jun 2020 at 6:25pm |
One of my D-14s started running rough... needed choke and it's 100 in the shade... ..dang no gas to carb.... after 2 hours of yank tank, clean it, sediment bowl looked OK, blow out gas line...still lousy... took sediment bowl off again... thought I saw something, na.... Ok, I did see something... it was a sliver of yellow in the inlet port.... WTH ???? all I can think is that it was a piece of plastic gas can nozzle that got shaved off poking spout into the tank filler hole. When ?? I don't know... but that is what stopped a D-14 !!!
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 15 Jun 2020 at 3:18pm |
OUCH jay......
Seein as it was that small Jeff, it'll prolly never be a problem. |
