8010 vs 8030
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Topic: 8010 vs 8030
    Posted: 10 Jun 2020 at 12:06pm
Baled hay last weekend with the 185. It was 98 degrees. I can't take that heat anymore. Trying to stay orange. Looking at 8010 with power director and an 8030 with power shift. I've never ran a PS before. Looks like the PD has more speeds.   Is there and advantage to the PS? I only do hay and shredding. The 8030 is 5k more with 1000 more hours. Both tractors have new paint and good tires.
Thanks Tim
2-B's,CA,D15,D17,160,2-185's 8010
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 12:25pm
The advantages of a PS are fairly straight forward. If you need (or would like) to change speeds often in the field under load, PS is the berries. If you road with a heavy load, PS is nice as with a PD you have to take off in road gear (low PD, but still a lug). At least for a 7000 series you do, my info may be dated.
If you can live with picking a gear and sticking with it for a long time, or don't mind stopping to shift, save your $5k if the power of the 8010 is enough. PS or PD are both very good transmissions in an Allis.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 12:42pm
If you'd technically be replacing a 185, then get the 8010 as long as it's 2wd. You will wonder why you didn't by one sooner! An 8030 having a 426 will use more fuel.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 1:24pm
I'd vote for the 8010.
Are you round baling or square?
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 2:41pm
I do 4x6 rounds. Picked up more ground so also looking to do 5x6 rounds. I love the 301 in my 185's. Just have to have A/C going forward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 4:01pm
8010 will do that job easily and save you fuel as said above. 301 is the best engine built by AC IMO.
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 5:52pm
Don't even think about an 8010 PD if you are going to get a 5x6 baler, I roll an average of about 1000 rolls a year. I use a pretty potent 8030 PS with a 5x6 roller, it's a wonderful hay tractor. Start off easy to get roll started then bump up to 4th gear and then on to 5th, when you need to slow down, just a tap to the clutch and back to 4th. If you need to slow even more just pull shift lever back a little further. A lot easier to go from forward and reverse also. I know I use lots of fuel, but to me it is well worth it! Just my 2cents
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 5:55pm
All 8000 series are nice tractors - but have heard the 301, which I luv dearly , are sluggish in an 8010, as they weight alot more than a 185 or 190 and the Ambac fuel system wasnt as good as than Roosa , just what ive heard and i have no experience with them
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 6:27pm
The 2wd were not sluggish, the mfd were.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 8:07pm
Good point Ed , there was more going on there with the MFWD
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 1:23am
Get the 8030 for the PS and the 426
Moneypit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moneypit Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 5:35am
I run a 7020 with a pd on the baler on hills doesn’t have any problem both of those tractors will work just fine
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 5:47am
Dad used 200 with canopy to spray until we got a ps 8010. He said he wished he'd bought it years ago. We have 650gl sprayer, the 8010 handle's it fine but rpm's need to be kept above 2000 to keep it from being sluggish. Still doesn't use much fuel. We have a 7020 pd that we use on a brushhog in the spring, not as handy as a ps for moweing waterways,ditches and around buildings as our 8050 ps. If it we're me, I'd want a power-shift for your application too. Keep looking for an 8010 ps or go with the 8030. You won't be disappointed with the 8030. Either way, your gonna wish you'd done it sooner.
Leon B Mo
Edited by Leon B MO - 11 Jun 2020 at 5:49am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 5:56am
Buy them both!
Darrel
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 6:21am
PS is a must if a loader is in it's future!    8010 fwa ps can be a little draggy.   i liked my PD for field work, the gear ratio's fit much better and the button on the floor allows one gear change up or down, with no stopping.  Talking about gear ratio's i loved; 7000 red belly with 3 speed auto.  just wish the 4 speed shifter hadn't been between my legs!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 7:05am
With a 5x6? Just curious. The weight difference is surprisingly HUGE. Do the math and see.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 9:43am
8030 I use a 8010 4x6 and like it but if I was looking at another 8000 series it would be 8030 P.S. period. Just my opinion. We are talking 38 year old tractors. If you find either with low hours ya better jump on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moneypit Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 11:11am
Yes just keep the rpms up. I use this he foot control a lot
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 11:29am
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 2:31pm
8030 2wd P/S is my round baling tractor and makes an awesome baling tractor.  Hesston 856 baler (5x6).  Have vermeer dealership in town and rented newer one several times.  Think 605M baler.  I ran that on 8030 and my White 105 and 105 seemed to be maxed out and sure pushed me around and pushed the temp guage higher.  8030 was much better tractor to handle that baler and i'm more hilly ground. Never had an 8010.   What do you use for a mower.  I run a vermeer disk mower. Power shift is awesome for that and can shift fast to slow real easy when coming to a ditch. Have a 7050 with P/D and rather have a P/S for baling.  I've used that one also in front of the baler, just prefer P/S. You'll like the 8030 cab, just make sure the A/C works good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 3:44pm
The effort required to de-clutch a Power Director clutch pedal all day long on a bailer would be enuff to make me buy the Power Shift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 4:35pm
My 82 year old dad still does it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 5:36pm
Bale kicker solves that problem
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 9:09pm
I know I want a 2wd.  Not doing much tillage work.  Just light disking of Coastal Bermuda fields.  This 8030 in Arizona looks interesting.   My only concern it was dueled.  Don't know if it was pulled hard.  It was a Arizona fish and game tractor.  Looking at flying over and having a look but not excited about getting on a plane right now.  Just not much orange in Texas.  I've never done a sight unseen purchase. https://www.tractorhouse.com/listings/farm-equipment/for-sale/21829605/1985-allis-chalmers-8030
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 9:31pm
The power shifts are nice until they go bad and then you need a second mortgage to fix it. Just my opinion after seeing what my brothers cost him when the "big nut" holding it all together went bad. Cost almost as much as the tractor did.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 10:03pm
The 426 engine and PS trans makes the better hay tractor. The low end power is provided by more displacement and you will notice this every time you stop and start forward motion. Big hay tools, high yields and high productivity expectations makes this a fact. You will never grind a gear switching from forward to reverse. The PS trans also shines on haulage work like moving bales spreading fertilizer or manure spreader work. I have a 7045 PD, a 7060 PS and a 190XT. If we put the 1034 stack wagon on the 190xt it gets along but the 7060 handles it like a breeze. The loaded wagon is over 12,000 and that is a lot to stop and start.  The 190xt with the hand clutch PD is neat to bale with especially on the older baler that wants the PTO shut off  (push in the clutch) to dump a bale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 10:11pm
I use a 1320 Hesston discbine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 9:56am
Still have to stop to wrap the bale.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 10:17am
I ran a 8030 ps on baler, liked it, tried a 7030 pd on balers didn't like that.
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 11:23am
I'm thinking they have had that 8030 on the lot since last year, maybe a lower offer for it would be in order.  The price seems too high for the hours, plus it's a 35 year old tractor.  I doubt if a green one of that vintage would bring that much.
