Factory front pump for 400 loaders
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Factory front pump for 400 loaders
    Posted: 09 Jun 2020 at 9:09pm
How many gallons per minute, or how much cubic inch displacement did the original front pumps have when sold with a 415 or 417 series loader? I think front pump for 519 loader may have been different.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 7:27am
I don't think there's a difference in the loader front pump GPM's on a D-19/500 ldr.  There was a D-19 auxiliary front pump to add to the 4.5 GPM belly pump flow and it would have been different and smaller than the loader pump.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 10:36am
I don't think they had front pump for the D19 like the D17. The pump like the D17 would be difficult to fit on a D19. The front axle support extends about 4 inches further out under the steering box and interferes with where the pump would mount. I have seen it done but it usually means chopping a big hole in the grill shell. It could be done with a longer shaft and mount spacers allowing the pump to be in front of the grill
Like Dr. Allis said, they had a smaller auxiliary pump using a flex shaft that mounted between the grill shell and the steering box. I have the pump, mount and diverter valve, but do not have the drive shaft or lines.
This page was generated in 0.127 seconds.
