Gleaner GM250 inline 6 starter
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner GM250 inline 6 starter
    Posted: 08 Jun 2020 at 4:25pm
Doing a few pre-season adjustments to my K2 Gleaner gas GM250 in-line 6 combine. Its engine starter drags some and/or just clicked with no crank. Anyway thinking it needs attention, I removed starter from combine, mounted it in bench vise, lubricated it’s bendix shaft, & wired it direct to good battery. Using a jump wire on solenoid, I got it’s bendix to move outward and then it’s motor seems to run good? It’s front nose housings armature bushing seems ok - it’s not excessively worn. So then I remounted starter on combine to which it will still only clicks hard, but no crank.
Why will it not crank? Need new Brushes? Thanks
Edited by AC7060IL - 08 Jun 2020 at 4:26pm
A-C_220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 5:49pm
Batterys or connections are bad maybe
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 6:30pm
Same battery on work bench & combine. It load test good. I cleaned combine ground mount to frame. But I did not replace any combine battery cables. So, I’ll try connecting same work bench battery cables onto combine. Thanks A-C_220.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 9:05pm
Can you turn engine with drive belt?      MACK
WD45 Aaron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 10:23pm
A couple years ago I had an intermittent no start condition with the lawnmower. Battery was good. Terminals were clean. At first inspection the cables looked just fine. Turns out the copper of the positive cable was completely green under the insulation near the battery connector. When I flexed the cable the insulation cracked and it became very evident. The cable appeared in good shape until I did that. The resistance was too high so the starter couldn't always draw enough current.
Edited by WD45 Aaron - 08 Jun 2020 at 10:25pm
Machinery rescue for all things rusty or broken. Current residents include 3-1/2 WD45s, Oliver Row 77 gas, 88 diesel, Farmall super C, parts C, two Cat D2's, Clark C500-80 forklift, and a sick Kubota.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 10:52pm
Yea,check what Aaron said, if the cables are old,or even the original,they could be bad...
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 10:59pm
My memory just jogged a bit. When diagnosing the issue I wasn't getting good continuity with my multi meter through that cable. That's what triggered me to take a look closer at it. Without the meter reading I might not have flexed it like I did to find the issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 5:38am
Yes
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 6:42am
Check the starter draw with starter in place on engine.
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 7:42pm
My combine’s problem ended being a bad ground cable. Thanks everyone.
