AC200 ran fuel dry; help with bleeding?
rickannable View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickannable Quote  Post ReplyReply Direct Link To This Post Topic: AC200 ran fuel dry; help with bleeding?
    Posted: 06 Jun 2020 at 5:33pm
Hello guys,
Dad ran the tractor dry of fuel and we are having trouble getting it to start. We've got fuel through the water separator and the filter, so I figure it's at least to the pump. I know once it's running we can crack the fuel lines at the injectors to bleed the air, but right now we have no fuel up there yet.
Does anyone have a really good description of how to get the old girl started again?
Much appreciated!
Thank you.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2020 at 5:55pm
You need to crack the line at the injectors before you start cranking. Watch for fuel and then tighter. Once it starts bleed each injector till it runs smoothly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2020 at 9:04pm
Pump primer and crank. I never bleed inj. lines if primer pump is good.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2020 at 9:27am
Loosen bolt on pump housing its right on the front facing you- takes a 1\2 inch wrench- get fuel there then go to your injectors
