D 15 clutch
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 clutch
    Posted: 06 Jun 2020 at 8:37am
Have a pretty bad engine rear main seal leak . Would this cause the clutch to be grabby ? Mostly leaks at WOT . THANKS!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2020 at 9:41am
Yes it can cause it to be sticky. Also cause it to slip under a load. Best to split at engine, replace rear main seal, tranny input seal, throw out bearing, and clutch and pressure plate from Rick Corder. Then good to go! HTH Tracy
Edited by Tracy Martin TN - 06 Jun 2020 at 9:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2020 at 10:23am
Thanks Tracy , I was wondering if the rear main seal and clutch could be done at the same time . My favorite son does have splitting stands now .
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2020 at 5:38pm
I can fix you up AC with the clutch unit and bearing...Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2020 at 5:43pm
Yeah Rick . My favorite son got his clutch and brakes from you . Thanks !
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2020 at 8:57pm
Yes!  You will have to remove the oil pan as well to position the rear seal properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2020 at 5:52am
Was wondering about the oil pan . It was off when I got this tractor . Quite the job to get the back bolts in IIRR . Might be easier to just pull the motor ? Thanks
This page was generated in 0.328 seconds.
