D17 Thermostat Questions
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Topic: D17 Thermostat Questions
    Posted: 04 Jun 2020 at 8:38am
After a thorough cleaning of the radiator on my D17 IV, the engine has been running way too cool.  Those little 1/4" bolts weren't about to come loose easily, so I removed the entire housing and did manage to get them out with some heat and soaking while twisting only one off.  I assumed the thermostat was bad, so I ordered a new 180 deg one.  It is the 2 piece style with a rubber gasket.  However, it looks quite a bit different from the old one, which is "taller" and has some ports that appear to let the water through into the bypass before it opens.  The replacement one looks like any other modern thermostat.  Also rather oddly, the old one appears to be stuck in the closed position rather than open, so I don't know why the engine is running so cold (it is full of coolant, no leaks and the temp gauge was an aftermarket one I put in a few years ago).  However, I still need to stick it into a pan of water and see at what temp it actually does open.  It is just odd that the engine runs to cold, unless a lot of flow is going to bypass.
So I guess my question is, is a modern "small" thermostat a suitable replacement for the original AC one, and should I go with a 160 or a 180 deg thermostat?  For modern engines from the 60's up, 180 deg was always the way to go (and later to 195 on auto engines), so I assume a 180 engine temp is fine for the newer D17 IV.
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 1:05pm
Here is a photo of the Gas Thermostat assembly.  I don,t see how a normal automotive thermostat could work.  I would source the correct replacement from an AGCO dealer.  Maybe Sandy Lake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 1:08pm
Looks like after some research, all the replacements use the two piece design.  It must work.  The thermostat should be closed and assembled so that it blocks the flow to the upper radiator hose until the 180 degrees is reached and the poppet opens.  The coolant should always have access to circulate through the bypass weather open or closed.
Edited by Bret (OH) - 04 Jun 2020 at 1:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 7:28pm
Thanks for the diagram and information. I checked the old thermostat in a pot of water on the stove and it opens at 180 degrees. I 'm going to study how everything fits together that would allow the coolant to bypass the thermostat to run so cool. The black round gasket appears to be ok. Interesting. It isn't rocket science but I'm curious what is going on. Should have left the radiator dirty I suppose.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 7:40am
Have you checked the accuracy of your temp gauge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 8:31am
Check block and radiator tanks with infrared gun.....probably not running as cold as you thought and a dirty radiator is not the answer.
Edited by SteveM C/IL - 05 Jun 2020 at 8:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 11:37pm
Those new 3 piece style thermostats do work just fine. I have them in both of my gas tractors. The D17D has a genuine Agco part in it. You want the 180 minimum, preferably a 195. The 160 was for use back when antifreeze was alcohol based. A hot engine runs cleaner, more efficiently, does not wear as fast, and doesn't foul plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 10:01am
Thanks for everyones' help on this.  I am now officially confused.  The new 3 piece thermostat I had purchased from Steiner (thermostat, adapter collar and black rubber gasket) does not fit into the thermostat housing, as far as I could tell.  Here are photos showing the original thermostat along with the new one.  I could see how the smaller new thermostat has to fit into the brass adapter, and would be the right height so the rubber gasket would seal at the top.  However, the brass adapter is simply too large to fit into the recess of the housing.   Perhaps they sent me the wrong part number, although it looks identical to the D17 thermostats on other vendors websites.
I tested the original thermostat in a pan of hot water, and it opens at ~ 180 deg and seems to be functioning ok.  After cleaning everything up, I put the old one back in.  It does seem to be working, as using an oven thermometer, the water circulating in the top tank is ~ 160 + deg.  It does seem the gauge is wrong, as it is showing half-way below 160 deg in the white region.  So idling the engine brings the water temp up to 160.  Once I work it, the gauge does get up into the green above 160 deg.  So it seems that with the clean radiator the engine is only barely getting up to temp at idle, which is not surprising.  I'll be ordering a replacement temp gauge, although at least I know everything is functioning correctly now.
It is odd that the new 3 piece thermostat is incorrect.  Either they sent the wrong part, or I was too stupid to figure it out.
Edited by Oldwrench - 08 Jun 2020 at 10:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 12:46pm
did you get one for a diesel VS a gas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 12:42pm
That thermostat will work. Glue the rubber ring to the outlet side of the thermostat with some 3M Super Weatherstrip Adhesive. The thermostat sits on the brass saddle. I prefer to glue the gasket to the housing. Makes for one less loose part to have to hang on to as you put it together.
This page was generated in 0.355 seconds.
