Coil not firing
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Topic: Coil not firing
    Posted: 31 May 2020 at 8:06am
I've got 2 wd's. When I put the coil (no external resitor required)in one it fires. When I put it in the other it doesn't. When cranking engine I have a jumper wire from positive side of the battery to positive side of the coil. Negative side of coil and distributor getting juice. But when I crank it over and hold the coil high-voltage cable a short distance away from the coil there is no spark jumping across. (When coil is my other WD it works fine) Where should I be looking for problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 8:08am
any chance you've got a 'hidden' ballast resistor in the nonfiring one ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 8:13am
Points are not making contact. Need cleaned, adjusted, or replaced.        MACK
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 9:27am
points or crap condenser.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 10:35am
      I have had two tractors that a new condenser solved the firing problem on in the last 3 years. Wondering if condensers are not as good as they used to be. Neither of them had much running time on them. Both had juice to the distributor and fired right up after the condensers were replaced. Good luck.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 11:54am
   I had one early this Spring that I put in and it was no
good brand new. Took it and got another and we were
good.
     J carlson
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 10:01pm
Are you talkin "hidden" within the coil? I was using the same coil for both tractors and it worked in one and not the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2020 at 5:26am
I found a 'hidden' ballast resistor on a D14 years ago in series with the OEM one  and tucked away under the gas tank......it'd just looked like a bunch of wires had been taped up for a 'repair'.....
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2020 at 5:45am
To avoid some guessing. Are both 12 volt conversions? (Coils labelled as not requiring an external resistor would be 12 volt, from the ones I've seen) Are both negative ground?
On the one that won't start: if you put a test light's probe on the coil terminal (negative?) for the wire going to the coil, does the light flicker (or go off and on) when you crank it over. If the light doesn't Flicker, or go off and on, check the points.
Edited by Jim.ME - 01 Jun 2020 at 5:48am
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 12:23pm
Thank you all for your input! Haven't been able to get on this site for a couple days for some reason. Site must have been down. Turns out I replaced the condenser and no change, but when I replaced the points it fired right off and runs fine!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 2:36pm
Happy news, indeed! Thanks for reporting back.
WC, CA, D14, WD45
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 4:39pm
Both tractors are 12-volt and both are negative ground. I'm glad you brought that up because I hadn't thought about that. I do have another WD that is 6 volt with positive grnd. Thank you for the tid bit about "coils not requiring a resistor" being for the 12 volt. Thanks for the info on the test light flickering when cranking also.
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 4:40pm
You are welcome!
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2020 at 9:58am
I was out messing with a couple of my WD that are both 12 volt electrical systems. One has a coil that says 12 volt external resistor required. The other one says 12 volt no external resistor required.
Both run well.
I attached pictures of both coils but not sure they came through correctly.
Your thoughts?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2020 at 11:25am
External resistor coils, were put on vehicles that the ignition started on 12 volts and ran on 6 volts.
Coils without resistors started and ran on 12 volts.
Supposedly the ones with resistors started easier.
All WD's came with 6 volt systems.
Dusty
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2020 at 5:03am
Thanks Dusty!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2020 at 5:54am
just to add more confusion ..
my '67 Mustangs had a clever  'ballast resistor bypass' that allowed full 12 volts to the coil while starting the engine. we all KNOW starting drops the battery voltage waaaay down and with regular system a weaker spark. Ford's 'better idea' was actually better.
Jay
