wd 45 fire rings
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 fire rings
    Posted: 30 May 2020 at 8:12am
Do I need the fire rings the new gasket set did not have them when I tore it down there was no rings with the new gasket on the block there is a space between gasket and inside of sleeve about a 1/8 inch if so does Agco have them or are they available other places Thanks Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 9:18pm
If it is a gas, they are made in gasket.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 7:47am
Tom,
Here is what my gasket kit looked like on the WD45 I rebuilt a year ago.
Maybe this will help?
We need some pictures of your project!
 Regards.
Edited by Sugarmaker - 31 May 2020 at 7:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 8:05am
It is a 230 diesel
Edited by Tom IA - 31 May 2020 at 8:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 8:10am
Well that may change every thing!:) Sorry for the gas information, I am not a expert on any of this, and did not pick up on the "fire ring" being diesel engine terms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 8:26am
Have not seen the latest head gasket but have heard they were made like the ones in pictures above.
If it needs fire rings, I can make you some that that are better than what comes with gasket set.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 6:30pm
my head gasket looks like the one above has metal rings on the inside like a gas gasket that's the way the old one was just second guessing myself just don't want to have problems once I get it going done lots of gas but this is my first diesel blocks been rebuilt for proper sleeve stand of pistons machined
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 6:51pm
You should be ok.      MACK
This page was generated in 0.140 seconds.
