Hand Crank Placement
NE GA Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Topic: Hand Crank Placement
    Posted: 29 May 2020 at 4:01pm
Hey all, was there a factory storage placement for the hand crank on a B, C, CA that has a battery box? I know that the non-electric tractors had a clip on the back of the tool box and it went down in the toolbox right below the steering tube. Not sure if that’s the same place if you can fit the crank over the battery box.
Thanks in advance.
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s,
1 WD45, 3 D15D’s, 1 D17
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 8:14am
I never ran across a mention of storage place for the crank on newer B. Someone told me you could manage to work them into the tool box but I don't think it will fit very easy and it would have to be absolutely empty.
Edited by Rick of HopeIN - 30 May 2020 at 8:14am
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 10:34am
https://www.allischalmers.com/forum/handcrank-storage-electric-start-b_topic12444.html Here is an old link about the subject. I just leave mine in the crank hole in the front. But I did change the placement of the smaller round pin so it won't fall out. (If that makes sense)
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 11:01am
Thanks for the link. I tried searching the forum and was not able to find anything.
I’ll see if I can get it in the tool box, or maybe make some clips and mount it to the side of the tool box.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 12:56pm
Dad just stuck it in the tool box going forward and left the rest hang out.  I also remember him sticking it in between the tool box and the steering shaft on one.  At a show I saw one clipped onto the seat back, looked good.
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 4:28pm
I have my seat shimmed up about an inch and a half and store the crank under that.
