Cub Cadet 782? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Topic: Cub Cadet 782?Posted: 26 May 2020 at 8:44am |
I bought a Cub Cadet 782 last year. It will not fire. Turns over well. Put new coil on it, no change. I haven't got a manual for it yet. I know some of these had a troublesome switch or two. Any of you guys out there have one of these? What is most likely killing the fire? Thanks Tracy
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4279 |
Posted: 26 May 2020 at 8:51am |
Tracy, I have a 782 that is my favorite mower tractor! It's just comfortable for me. On the no fire, would guess the usual suspects? Points, condenser? The deck engagement switch could be a problem, have fought that a time or two. Also have a 1450 and a 1650 CC. Got a new switch off E-bay once that was backwards! 1650 would start if the pto was engaged but not if it wasn't!
Grayray
Joined: 12 Sep 2009 Location: Ambridge PA Points: 3860 |
Posted: 26 May 2020 at 8:58am |
Maybe the seat safety switch, the one where if you lift your butt off the seat, it kills the engine? Maybe look for a bare wire going to one of the safety switches, maybe a mouse had lunch on the wire during the winter.
IBWD MIke
Posted: 26 May 2020 at 9:02am |
Grayray, I don't think they have a seat safety switch. One other possibility could be the 'neutral start switch'. My 1450 if you don't have the brake pedal in just the right spot it won't start!
Tracy Martin TN
Posted: 26 May 2020 at 9:43am |
It has a seat switch and the neutral pedal switch. Checked both of them. Has a pto switch lockout also. I wonder if the ignition switch has went bad. Heard that they were a problem. Any help appreciated. Thanks Tracy
john(MI)
Posted: 26 May 2020 at 10:58am |
We had to replace the the ignition switch on a friends. He we just hot wiring it for a while before he decided to change it. Same problem you have.
Tracy Martin TN
Posted: 26 May 2020 at 11:13am |
John, I will give it a look. Thanks, Tracy
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 26 May 2020 at 5:42pm |
![]() this might help with the trouble shooting..... 'borrowed' from ... https://www.onlycubcadets.net/forum/showthread.php?t=21https://www.onlycubcadets.net/forum/showthread.php?t=21 Jay
Tracy Martin TN
Posted: 27 May 2020 at 8:51am |
Jay, Thanks Tracy
jaybmiller
Posted: 27 May 2020 at 11:33am |
Always happy to help. If yours has a higher serial number, that website has another wiring diagram.... Jay
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 27 May 2020 at 11:38am |
Don't Know which one you got Serial# wise, but here's a site to download 4 different Operators Manuals.
chaskaduo
Posted: 27 May 2020 at 11:52am |
Found these chassis service manual HTH
And
Tracy Martin TN
Posted: 27 May 2020 at 1:20pm |
You guys are info specialist! Thanks tracy
