83 allis chalmers 715c cylinder help |
ac89
Topic: 83 allis chalmers 715c cylinder helpPosted: 25 May 2020 at 6:55am |
I need a dipper cylinder for the boom it blew the cap off. Any help would be greatly appreciated. I don't know of any bone yards that would have it. I tried general gear but their machine is a 715b nothing is the same.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 25 May 2020 at 12:18pm |
Are you sure - I have a AC 615 cylinder now on my 715B .
You should be able to repair the cylinder by having a new end cap made or try MINNPAR to see if they have the part . The other option would be to make a retainer to clamp or weld to cylinder body then using a plate and bolts to anchor end cap to retainer . On one cylinder i had where threads were damaged I cut the cylinder off about 1/4" which allowed the end cap to grab good threads by moving further up threaded area . |
DougG
Posted: 25 May 2020 at 4:34pm |
Sounds like a stupid kid post
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35671 |
Posted: 25 May 2020 at 6:18pm |
Any hydraulic shop worth their salt can reman the tube with a new head end.
ac89
Posted: 25 May 2020 at 9:14pm |
I found a place online that I can get a new end cap so I think I am going to have a machine shop make a new barrel. I want to do it right and not have to do it twice. I only asked on here to see if anyone had a cylinder or knew of a place that may have 1. I'm not a dumb kid I don't really appreciate the insult. I actually just got done rebuilding 4 cylinders by myself. I have 10 allis chalmers tractor's I'm not new to working on equipment.
Coke-in-MN
Posted: 05 Jun 2020 at 10:18pm |
Why replace the barrel ? It seems the threads in the cast end cap are the ones that get worn - After I repaired that cylinder and it has only ran for 20 years now .
But I had this thing of how much do I spend to how can I repair it myself - finances said fix it myself . |
ac89
Posted: 06 Jun 2020 at 4:24pm |
I was hoping it was just the cap but the threads on the barrel are stripped beyond use actually both the cap and the barrel are stripped.
