Looking For Wheels For 5215
dbounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbounds Quote  Post ReplyReply Direct Link To This Post Topic: Looking For Wheels For 5215
    Posted: 24 May 2020 at 9:01am
Looking For rear ag Wheels for a 5015 or 5215 . others may fit also,Tire size is 9.5 x 16, wheels are 8x16. or if you know of a small tractor salvage yard. Thanks Doyle
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 8:53pm
Doyle, my MF2705E 4X4 has the ag tire option with the 9.5-16 farm tires on the front. 6-bolt pattern and may fit. Might be something to check with tractor salvage yards.
IB (restoring), MF GC1705, MF 2705E
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 1:31am
whats the bolt pattern 4'5'6 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbounds Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 6:20pm
6 hole, 5.5” stud pattern, and 3.5” center hole opening
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 7:01pm
that rim size is common for older Chevy trucks........ You could use white wagon wheels as an option ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 7:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 7:21pm
Most 16 inch rims are going to  be 6.5  - 7 inches wide.... 8 is a little harder to find..
