Allis 6060 starter /seliniod running update
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Allis 6060 starter /seliniod running update
    Posted: 22 May 2020 at 3:13pm
Finally got over to check it out- they undone the hot wire - the one direct from the battery, when you put the hot to the place on the starter the bendix- selinoid runs continuous, with the key off- with the key on-  it does not engage the starter, just runs- only stops when you take the hot off- i rapped on it pretty good with a wrench and no change- also the owner said the last time when he pushed the clutch in the brake light came on and the air cleaner light did too
Edited by DougG - 22 May 2020 at 3:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 3:54pm
Not sure how you ENGAGE the solenoid... Normally there is a push button on the dash or floor that you send a 12 v signal to the solenoid with a SMALL WIRE... That pulls in a electric magnet and the BIG WIRE from the battery contacts the BIG WIRE  on the starter.... Either you solenoid is fried and stuck ON all the time, or the small wire is sending 12 volts from the switch............ take the SMALL WIRE off the solenoid, then try to connect the BIG wire from the battery... If that works, you SWITCH IS STUCK ON.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 3:56pm
Since the starter runs all the time and does not engage, your Bendix might be broken from the constant running... Even if it is the SWITCH, you probably still need to remove the starter and check the Bendix... If it is NOT the SWITCH stuck ( small wire), then the Bendix is the entire problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 9:06am
These do not have the push button start- its all in the key switch, turn it far to the right starts it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 2:19pm
Another update- put a rebuilt starter on this morning and started once - now clicks - isnt there something about a voltage drop ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 3:35pm
If the solenoid clicks then you are sending the signal from the key to the starter on the SMALL wire.. If the starter does not kick in and crank, then you have a bad ground , battery is dead, or new starter is bad......
Since it was doing a lot of spinning when it stuck, i would put the battery on the charger over night... also check battery terminals and cable ends / ground strap... and the LUG on the starter for tight.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 5:22pm
They Had A Voltage Drop With All The Safety Switch I Put A Relay On All The 6060 6070 6080 Put On The Small Wire To The Solenoid
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 9:38am
Last update -- finally put a relay on it - and works perfect! Wiring is not my specialty - but I got it , it was actually pretty simple once i understood it ! Thanks to all who chimed in !
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 12:20pm
This can happen on any tractor. Its not just Allis.
I've had to replace safety switches on other makes to make the starter perform.
You still might want to check the adjustment of the switches and the switches themselves with an ohm meter.
These tractors are getting old and they have done their time...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 3:41pm
All switches work , and in specs,, as safety first!
Edited by DougG - 31 May 2020 at 3:44pm
